Putting aux lighting switches in cubby
P
pcfranchina
Secret compartment door? Never really thought of adding a USB but thats not a bad idea. :)
I just took a quick minute to pop out the cubby... Its pretty thick. The plastic I picked up to go there is only 1/16. How did you attach the plastic plate? I was just thinking to cut the back of the cubby off and use the plastic plate right on top of it to hold it all in place by the pegs and clip and make it more sturdy. How did you guys attach the plate with the usb and rocker switches?
kwood129
I will take mine apart tomorrow to show you how I attached mine. Here are a couple of pictures if the secret door. Not really a secret and my usb ports are for charging things. My goal was to keep things hidden as much as possible.
Sent from my XT894 using Tapatalk 4
P
pcfranchina
Hmmm I'd say my console is a little different. I already drilled through the back end of inside of the console. I ran my CB antenna cable in there. All hidden.
kwood129
The denali center console is different. They have that door inside because things can fall down in there so easily when you lay them on the drink older cover. I've dropped my phone in there twice in the past couple of months
P
pcfranchina
Well over all the day was a success. Added 2 LED spot lights to the front bull bar and one on the rear of the cargo rack. Deleted the cubby, added a plate with 3 switches, blacked out my red front and rear GMC badges and mounted a maglite. excuse the low quality iphone photos. I will get some real photos next time I'm out there playing.
kwood129
I have added a few more switches to my cubby. Its starting to get a little crowded on the backside with all of the wiring.zuryvaga.jpg
Pete315
