Question about lug nuts
RSalander
VA Beach
I bought some new lug nuts for my wheels that arent open ended. I feel like they are not deep enough to keep the wheels tight to the hub. Can i put some washers on the lugs first then the nuts?
04Hoe
Do not use washers,,If you think they are wrong take them back.
Modded
That Guy
If they are atleast 1.4" long like most closed end lugs are, then you will be fine!
R
RSalander
VA Beach
Well I bought the kit from the zone. (the locking lug kind). I put the locking lug on and it literally pushed the center out of the lug nut and exposed the lug stud.... just doesnt seem too safe.
Modded
That Guy
Are you sure you did not just overtorque?
If not, then that means those AutoZone lugs are cheap as hell, and you will ned a longer one.
01yukonslt
need more deebeeeez!
Spokane, WA
they are cheap as hell i bought a set and did exactly the same thing they are junk and the locking lug nut bottoms out before its tight because its even a 1/4 inch shorter than the rest. i bought gorilla extended lugs and haven't had a problem since.
R
RSalander
VA Beach
1, if i over torqued them and it did it then it would mean i was crushing the wheel
2, whered you get the gorilla nuts and how much?
01yukonslt
Spokane, WA
i bought them from a distributor here that deals directly to les schwab and all the major tire stores so i got them for 50 bucks with the key. les schwab wanted 106 after taxes. best and cheapest way would be to order them off of ebay probably for the best deal i was kinda in a time crunch and have connections so it worked out for me.
sterrynbama
