Tbruz
My 1997 Tahoe with 165K miles has started exhibiting what may be a tranny issue.
Truck is babied and has always been over maintained. Tranny fluid and filter was changed at 90K miles, truck now has 165k.
It will shift fine 1st thru 4th gear every time during regular acceleration and will also downshift fine 4th all the way thru 1st, every time.
If I slow down to only around 45 MPH and then immediately try to accelerate from there, the tranny seems to be confused as to which gear it should be in, 3rd or 4th.
If I go slower than 45 it will up shift fine, if I punch it at 45 it will up shift fine.
This happened once or twice months ago, but seems to be happening with more frequency now.
Can a good shop pull codes of a transmission to see what is happening or are they immediately going to say Rebuild?
Googled and found some stuff about solenoid packs maybe..........
Don' really want to rebuild, but t curious if it is solenoids, can they be changed out alone or ar eyou already in so deep at that point that a rebuild is best.
Any help or ideas appreciated.
Thanks in advance
Tbruz
Thanks in advance
Tbruz
