question...
aloha_bruddah
Probably needs to go in the suspension section but............
I know it's dumb, how do i know if my Yukon is lowered? It has 22" on it....
maybe i should post a picture?
let me know, thanks...
NathanJax
Vacation Nathan
Administrator
Jax, Fl
moved to suspension section ;)
We need a pic to tell. You would have to look to see if you have aftermarket springs or keys or spindles.
A
aloha_bruddah
pic
Here's one....... damn email's acting weird today....
Alex33
It doesn't look like it's lowered. Best bet is to measure from the ground to fender. I think most trucks are 35-36" in the front and 36-37" in the rear from the factory.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
x2
make sure you're on a flat/level surface
A
aloha_bruddah
will do, thanks.......
so hopefully replacing shocks, springs, should clean up the ride? I guess i'll have to crawl up underneath it to see what all needs to be replaced? Any suggestions? it's gonna need brakes, but i need to see if that's what's causing the abs and brake light to come on. I also have a service suspension message, or something like that....i'll look again....
Alex33
ABS and brake light could be an EBCM failure. Does your truck have the autoride option?
Alex33
your guess is as good as mine, how can i tell or check?
If you have autoride, there is a compressor either behind the driver rear wheel or under the passenger side second row mounted to the frame. Your rear shocks will also look like air shocks.
A
aloha_bruddah
yes, i have the autoair susp....... front and rear shocks are shot, i would guess that compressor is bad too...... i'll be disabling this and putting in normal shocks.....
ddk1993
