Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
:cheers:
looks like i have 15-1/2 to the hood from the valley deck, the 1800hp should fit
You’ve been cleared to spend more money! Carry on!
randeez
randeez
south florida
it hurts my heart not to save 200 bux, but i think imma pass... for now.
mostly because thats just the tip at this point, before i could even do anything with it id need a water tank, couple hundred bux in fittings and hose, want to do a chiller system also...basically thats only about 1/2 the cost of doing a2w how i want to
Did you not see the gif?
Administrator
they make a 2k hp rated one, but im pretty sure it wont fit under the hood.
talked with someone that had one with a gmt900 truck and he said he had to cut the cowl and removing some of the hood bracing to fit, but wasnt real clear on which one he had and hi ram base, motor mounts, etc
going to pull the hood insulation pad off tonight and try to get a real good measurement of what can fit
You don’t need no stinkin hood!
that is like 90% of the reason im doing this, to show you up
:lol:
Dantheman1540
Sugar Loaf Mountain
Those big ole AN fittings get expensive fast!
Austin12
