i am waiting for coworker to weld bungs on the radiator, when i get that back (prob this weekend) is sets off a cascade of crap i can do after that
after its back in, hopefully the electric water pump will mount and hose route should be good.
electric fans can go on radiator and i can finish fab on the charge pipe, i need to come off the turbo and angle pretty sharp to clear the electric fans. i bough a cheap cast 3.5" 90 and cut it down to a 30, but its so porous i think its just going to turn to liquid if i try welding to compressor housing, but ive got a silicone 30 that i can use instead and prob will.
after the charge pipe is in i can lay out the waste gates and get them mounted, will prob just be dumped out the bottom for now.
ordered stuff to finish up ac lines, ditching the factory suction line all together, just doesnt work out good.
i had the injectors cleaned, i should prob just throw them in and get rolling but the longer it sits, theres a better chance im going to go ahead and get some larger ones. along with new fuel pump. just havent pulled trigger on them yet cause what i have will atleast get me moving.
