Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
Need to measure fenders but doesn't really matter till coilovers get here....43" back, 42" front. Should be able to make that up with coilovers
And whatever size tires I go with
View attachment 362474View attachment 362475
What fan are you using in front of the tru cool? I assume it is a reverse (push) fan?, how do you have it hooked up? I moved my trucool down to the bottom but i would prefer it up top
does the fan stay running at highway speeds?
I'm curious because having the trucool in front gave me some minor heating issue's at higher altitude
randeez
randeez
south florida
i ordered a flexalite wave fan but it backordered forever, i didnt want a "cheap" fan so i thought ill order a "be-cool" fan - came in a spal box :emotions122: not that spal is all that bad just wanted a notch above it
i threw it in when i was haing ac problems at idle (turned out to be orifice messed up) but i left it. its wired on all the time but prob just going to put it on a toggle switch and hit it if i notice temp start rising
randeez
randeez
south florida
o...and i started it lol
started making the changes to the crossover and got like halfway thru that with thick af wire, boogered it to shit cause i just wanted it done, ran out of wire - so it looks like shit and i have to wait for wire to come in to finish anyway :rofl:
need to order half a 4" vband also to reconnect to rest of exhaust it managed to line up perfectly with where i vbanded the last downpipe/4" part. pretty sure i didnt plan it but ill take it
going to need atleast 1.5" wheel spacers for the back too, front track is way wider now
randeez
randeez
south florida
it looks like 37s needs 6"+3" body lift? or 8+ all lift? and both STILL need trimming?
not sure if its worth it atm, so looks like 35s
ordered what i needed to finish up exhaust, and put it all back together.
ordered some 1.5" spacers for the rear
still waiting to hear on axles
