Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
bigfootchiro
Largo, FL
Its what's on the inside that counts? :anitoof:
Kind of a let down to bust it open and see an old, but very cleaned up and painted, case. But knew it was what was coming, said they like to use the older case for fluid transfer or some crap. Alas the entire case has prob been hot tanked, cleaned and painted no one will ever see more than the pan anyway.
I threw an old short hose I had laying around to loop the cooler fittings. And made sure the transfer case adapter works. It is about 1.5-2" longer than the 6l80
View attachment 225221 View attachment 225222 View attachment 225223 View attachment 225224 View attachment 225225
I’ll be over to pick up my transmission. Thank you
randeez
randeez
south florida
Real close to throwing it in the garbage lol
Been fighting with getting converter on for a day and a half now. wanted to measure to flexplate and couldnt get it to seat took o ring off input shaft and slammed it in, now I gotta try and do it with the oring on
Ruined the oring yesterday, couple chunks missing so I already ordered a new one
Wish I could help ya Randy!
randeez
randeez
south florida
that's why I asked how that was going to work, I had thought about doing a better intake on mine and had read up on what all it would take, not a lot of info out there but one reviewer had said he had to do all kinds of stuff to make it work but that it was worth it in the end
honestly its probably 95% cosmetic lol. the stock intake will work just as well up to about 4500-5000rpm, stock intake being composite means it wont heat soak, obviously all the extra work needed to make the hi ram work.
at this point ive just had the hood popped so many times at cars and coffee or the track or where ever some one gives me a goddamn whats in that thing . i wanted to be able to pop the hood and make it look like i tried to clean it up
randeez
randeez
south florida
I'd be dangerous with a real shop...
Home at 5...trans in, converter bolts in, starter in , cleaned up and out to dinner by 7
also circle D got the spacing real close, ended up just need a small washer to keep it at 1/8" pull back to flex plate (which they included)
brilamb21
