992dr
Last week my wife was driving the Tahoe and noticed the "check gauges" lite came on. To make a long story short, he temp was running higher than normal. I left work thinking it was the temp sensor, reason being. When I had my headers installed, he broke the connector and I have to check it frequently to make sure its attatched. Well, that was not the problem. I ended up looking inside the radiator. I was rather surprised to see it was very low. I added some water and it was fine. I checked it a few days later and it needed more water. I asked my wife to let me knwo if she sees any spots on the driveway. Well, tonight she saw one.
I got under the Hoe and noticed coolant dripping from the bellhousing. The same place where oil was dripping before I put some Bar oil in.
I'm almost posotive I need a rear main seal.
Why would coolant be leaking from back there? Could it be the rear main seal?
Any and all info would be greatly appreciated.
Thank You
Thank You
