Random Coolant Loss, need some info asap
arb905
I really hate to beat a dead horse, but....have your intake gaskets been replaced? If they are the plastic ones they can create a crack that will not only leak into the intake manifold but also to the back of the motor and create a drip. Before you yank the trans to replace a freeze plug check it out. May save you a lot of trouble.
I know this because it hase happened. I had the random coolant leaks and then the check engine light for misfires and lean codes. Good luck.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Don't be and do the dye before yanking every thing out. If you had coolant coming out of your rear main seal you engine would likely be seized or your block cracked already open as a result for which no oil seal will fix.
992dr
992dr
Eastern N.C.
arb,
I know all about the intake gaskets, it was replaced in 07. My other problem is the rear main seal, it has been leaking for some time. I cant relying on Bar Oil for ever, hah.
sun,
Sorry for jumpin on yah man. I'm just aggrivated. I will use the dye tomorrow after work. I need to clean off the motor some to be able to see better.
Random questions.
1.) I notice some kind of cap on the bottom of the bell housing. Can I pop this off to get a look inside?
2.) What are other common areas that leak oil near or around the rear main seal?
Thanks guys, please excuse my tone. I dont mean to take my frustration on anyone here.
SunlitComet
OBS Jedi-Do Good
1. A cap or more like a cover shield on the bottom?
2. Oil cooler adapter if installed to the left of engine. The oil pan but the oil pan gasket is multi-ribbed front and back for the engines oil holding pleasure not to mention pan rails that are used.
992dr
992dr
Eastern N.C.
Hmm, its on the drivers side of the bell housing, its round and has three notches in the bell housing and three tabs that are bent inside of the nothes. Looks like thin material, like a stamped peice of sheet metal.
The oil cooler adapter, when you say left side. Do you mean the drivers side?
I'm going to go to a local DIY car wash tomorrow and washer down so I can get a better look at everything. This time I'm bringin the ramps, hah.
Thanks man, I appreciate it.
Oh, I forgot to mention. The coolant is down again. I did not add any. It seems when I add water, it leaks. After I cleaner up I'll add some water with the dye. Hopefully I'll get a better idea of whats going on.
SunlitComet
OBS Jedi-Do Good
sounds like an inspection cover to me to access flexplate and converter bolts. pop it. Oil cooler is on drivers side.
81939524
have you check your cooling system
reservoir housing or hose for cracks or leaks?
You should also have the oil pressure sensor fitting in the back to to the left I think to look at as well.
clean454
if ur going to use dye get 2 diff colors one for the oil one for the coolant...
992dr
992dr
Eastern N.C.
Thanks for the helps guys, I really appreciate it.
Well, I finally was able to get under the Hoe and get a good look and idea of whats going on. sunlit, you're right, it is an inspection plate. Popped it off and got a decent look inside. Saw nothing, it was very clean with little to no oil or water residue inside.
What I did notice is the water/coolant is coming from the front of the motor/waterpump area. AND the oil that I saw that was noticeably wet, WAS around the oil pan and the oil cooler adapter plate.
This is very relieving. Not a bad job at all, I'll have it done in no time on Saturday.
Thanks again evveryone.
clean454
the adapter plate looks easier then it is!!! LOL
it kicked my ass one time but now i got it down!!
992dr
992dr
Eastern N.C.
Any advise you can pass on for the removal of it? Tip or tricks?
Thanks
yashchitre
