Dustin Jackson
- Joined
- Aug 9, 2018
- Posts
- 1,551
- Reaction score
- 1,750
@iboughtatahoe23 I see. Well at least our test was successful, pick your preferred way of disabling AFM and proceed
Then drop a crate motor in and we good.Personally, I think your situation is more of a now thing instead of a later thing. From what you are describing, you very likely have compromised lifters and the longer you run them, whether they are making noise or not, the greater the risk that you will have a catastrophic failure of a lifter which can take out your cam completely and send metal through your motor.
I hear you man, but it’s tough bc I have this on a loan and don’t wanna throw money at it if I don’t know 100% that it’s the liftersPersonally, I think your situation is more of a now thing instead of a later thing. From what you are describing, you very likely have compromised lifters and the longer you run them, whether they are making noise or not, the greater the risk that you will have a catastrophic failure of a lifter which can take out your cam completely and send metal through your motor.
Seems kinda inconvenient I’d be out of a car for a few weeks, got a job to get to that’s miles away so not sure how that would work. Might just buy that range AFM disabler and call it a day@iboughtatahoe23 I've heard good things about this guy, this will be cheapest option in tuning AFM out: https://lt1swap.com/afm_delete.htm
Also not experiencing any lifter failure symptoms I don’t think… what are the symptoms?Personally, I think your situation is more of a now thing instead of a later thing. From what you are describing, you very likely have compromised lifters and the longer you run them, whether they are making noise or not, the greater the risk that you will have a catastrophic failure of a lifter which can take out your cam completely and send metal through your motor.
Well…..When I had a lifter fail on my 2007 non-AFM 6.2L the symptoms where a loud screeching/tap sound. Nothing else. No misfires, no codes, nothing.Also not experiencing any lifter failure symptoms I don’t think… what are the symptoms?
