? re Gatorback Serpentine belt ...
Xav8r
Greater Sacramento
Hey Guys & Gals-
Can anyone help me out and tell me which Gatorback Serpentine belt I need?
'01 Tahoe LT
5.3L 4x4
I've looked on a few websites and can't tell for certain which I need. On SummitRacing it looks like there are at least three different options.
Sorry if this is a rookie/noob question.
Thanks
jd08
Jackson, WI
Look on www.rockauto.com They make you select you vehicle and then they tell you which ones are available. They offer Gatorback belts. I ordered a set for mine. Rock auto is one of the best online parts stores.
THE YETI
Director of Operations
South FL
Neither. Run a Gates. Gatorbacks are garbage.
X
Xav8r
Greater Sacramento
Thanks fellas.
Don't know why I didn't look on RockAuto first. They sure made it a bunch simpler.
What's the story with the Gates vs. Goodyear Gatorbacks? It sure seems that a number of people on this site prefer/suggest Gatorbacks. Although I'll be the first to admit that I don't know much other than 1) No local parts stores stock them 2) the local shop was using Gates 3) at some point a belt is a belt ... anyway I'm all for learning from anyone who has knowledge and experience regarding this.
While I'm on the accessory subject, can someone tell me if I add the "overdrive alternator pulley" from BlackBearPerformance if that changes which belt I'll need?
Thanks again!
03YukonNH
Manchester, NH
Thanks fellas.
Thanks again!
I used the stock size after switching pulleys. No problems
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Gates is suppose to be better than oem, according to my bosses. In 2 1/2 years of working at an auto parts store I've never had one return. That goes pretty far when you consider I stock 6 dealerships (2 of which are GM) and many more shops with my stuff.
Sent from my myTouch_4G_Slide using Tapatalk
Rivieraracing
Gates are awesome belts, I had an old blazer with a big alternator that was throwing belts like they were nothing, even went through 3 different brands of belts before finding the Gates, haven't had to replace one since and that's been 5 years now!!
THE YETI
South FL
Gator backs have been known to break apart/shred. When I was looking for belts for my silverado alot of guys on Pt.net did not recommend them for that reason. I went with Gates. No issues. :)
1997tuhhoe
