Rear Defrost help
T
Tbruz
Windham NH
I am probing the grid on the imside of the glass.
I guess that as downstream as you can get.
Tony
---------- Post added at 07:14 PM ---------- Previous post was at 07:07 PM ----------
Can you post the p/n of the harness from Glass to door contacts.
Thanks,
Tony
SunlitComet
OBS Jedi-Do Good
unknown at this time.
You will have to try the dealer on that. There are no #'s available for the the wire harness. Actually quite common for harnesses. Can you remove yours and test it?
---------- Post added at 11:03 PM ---------- Previous post was at 11:02 PM ----------
I asked before but no answer, are the elements not working at all?
T
Tbruz
Windham NH
Dealer says that wires(harness) is a part of the rear glass, not a seperate part. This info was obtained on a phone call so I was not looking over the screen to point anything out .
If anyone has better info I'd appreciate it
My defog is weak(defrost non existant), based on only 4.5 volts getting to the grid versus 12+ volts.
Thanks
Tony
Tssonebay
