hcvone
I have been using Amsoil since the late 80's, yea I'm old, first oil change my diff's get changed also to Amsoil Severe Gear, been doing this for decades in all my cars and trucks
If I’m not mistaken, the G80’s do not need the friction modifier additive.
@Rocket Man or @Jolly Roger, either of you want to share what you learned about additives on the G80 differentials since you both went down the rabbit hole on this one recently?
I use Lucas Oil full synthetic gear lube for both my GL-5 front diff and G80 GT4 rear diff. I replace the fluids every 50k and haven't had any issues yet. 226k+ and still going strong. It works for me so I'll keep using it.
Pretty sure a GL5 is a RPO for "FLEET INCENTIVE CHAMBERS RENT A CAR" not an axle or gear?
GL-5 is not friction modifier either. It’s a specification for gear oil determined by the amount of “Extreme Pressure” or EP additive in the oil. GL-5 specification is the recommended gear oil for the G80 differential. More interesting info here and this brings me to the pictures I saw of the gears in @Dantheman1540 ’s differential the other day. Hey Dan, remember those marks on your gears that looked like someone had been welding on them but we all knew nobody would be welding on the damn spider gears? Read this and see if it makes you scratch your head! Oh, and s roll back to the pic I posted of the recommended ACDelco 75-90 I posted above here- it shows the GL-5 spec on the bottle.Thanks for calling me out on my typo. I was crafting a couple responses for a couple posts at the same time and got all mixed up with what I meant to say. Obviously I don't have a GL-5 front diff or a GL5 RPO code. I meant to say that I used Lucas conventional 80W90 gear oil in the front diff(without the GL-5 friction modifier) and Lucas Full Synthetic 75W90 gear oil in the rear diff(also without the GL-5 friction modifier).
Now I gotta find me a Chambers Rent A Car LS so I can have that GL5 RPO
08 July 2019
When you are choosing a transmission or gear oil you might be wondering what GL-4 and GL-5 mean and what the differences are between these two classifications. Choosing the right classification is extremely important since they both have different properties and wrongful use could lead to serious damage to your vehicle.
There are four different classifications for transmission/gear oil. These different classifications define a certain level of performance in driven axles and manual gearboxes. They are mainly important for the transport sector in North America, Africa and Asia. The active classifications are:
• GL-1
• GL-4
• GL-5
• MT-1
The higher the Extreme Pressure (EP), the higher the GL category is. It is important to know that the SAE Motor Oil Viscosity Chart (J300) is different from the SAE Gear Oil Chart (J306). The viscosity has no relation with the API Gear Oil Classification and should be chosen based on the recommendations from the manufacturer based on the temperatures where you will drive.
The main difference between GL-4 and GL-5 gear oils is the amount of EP additives. Sulphur/Phosphorus containing products are used as EP-additive. This additive has the purpose to prevent the occurrence of micro-welds on the gear flanks at the local high temperatures which prevail in EP circumstances (temperatures well in excess of 800℃!) GL-5 has roughly twice the amount of EP additives compared to GL-4, which is why it is often used in high-pressure circumstances such as in a front axle and rear axle differential.
Sulphur/Phosphorus additives however have an unfavourable property: they can react aggressively towards bronze and copper. This can be disastrous for the synchromesh rings of a gearbox. Therefore it is not recommended to use GL-5 in a gearbox unless the manufacturer allows this.
To conclude:
• GL-4 is suitable for hypoid gear service when they are under severe service but are without shock loading.
• GL-5 is suitable for hypoid gear service under severe service and shock loads and not for use in a gearbox.
