tarheelsfan2000
I am rubbing here. This is me laying under truck looking at driver rear tire driving it does fine but when I hit bump or turn it rubs.What are you rubbing?
The bolt is switched its rubbing on the metal by frame so looking at the driver side tire it is on left of it rubbing frameok kinda hard to see. Make sure to flip the upper bolt for the shock so head not the threads are sticking out because many times the bolt touches the tire
if its plastic just cut the plastic
Here is another pic of rubbing spot no just notice on driver sideis it the frame section by the front lower control arm bolt?
also do both sides do it?
