rear is rubbing.
Valdosta , GA
What are you rubbing?
I am rubbing here. This is me laying under truck looking at driver rear tire driving it does fine but when I hit bump or turn it rubs.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
ok kinda hard to see. Make sure to flip the upper bolt for the shock so head not the threads are sticking out because many times the bolt touches the tire
if its plastic just cut the plastic
Valdosta , GA
The bolt is switched its rubbing on the metal by frame so looking at the driver side tire it is on left of it rubbing frame
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
is it the frame section by the front lower control arm bolt?
also do both sides do it?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Is it just rubbing plastic or also the lower metal mount where lower a arm bolts into?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Ypu will need the spohn rear bar kit to move the axle back that I sell. Pm me.
You will see rear end is sucked forward my kit will fix that
ehernande86
