Rear locking diff?
Fishin757
VA Beach
I was looking at the gear code sticky above and felt a negative vibe goin with the G80 code. Why are they bad?
Fishin757
Fishin757
VA Beach
FUUUUUUUUUUUUU**** guess what i found..... what should i do now that i know i have a G80
---------- Post added at 02:06 PM ---------- Previous post was at 01:52 PM ----------
i dont do any crazy off road just go on the loose sand at hatteras and light mud at my friends
ChrisAU
Birmingham, AL
I have one too. The best option is to just wait it out. The carrier is made for the G80, so to rid yourself of it you basically have to replace the whole axle.
purple 'hoe
Green Bay, Wisconsin
Could you fit the whole rear axle from a 2500 in there?
Yes. A 9.5 14 bolt will fit. Some 1500's came with them factory. They are 6 lug. You can also find the 9.5 in a 8 lug fashion, which can be converted down to a 6 lug.
Also, I was reading a thread on another forum about converting a 10.5 14 bolt (full float) down to 6 lugs. That might cost more than finding a SF however. You will need a different u-joint either way. And some other small odd's and ends.
This is if you find a 14b out of a OBS truck. NBS, NNBS or OOBS would need some modifications however but very do-able
Fishin757
Fishin757
VA Beach
Sweet Hopfully I won't need to swap but it's good knowing I can do a swap fairly easily
Stevemo70
