Based on MJReynolds' experience ( https://www.tahoeyukonforum.com/thr...e-2007-tahoe-5-3l-135-000-miles.116461/page-8 ), I have decided to do my own rear main oil seal. He did not have to remove the transfer case, but I'm nervous about balancing the transmission and transfer case on a transmission jack with a jack supporting the transfer case. Also, if I get it out and find I have to remove the transfer case anyway, I might as well remove it first.
There are lots of videos on this, but they all omit important steps. I suspect part of the reason is the added time consuming process of video recording everything. Often there is no mention of fluids involved, removing all the electrical connectors from the transfer case, etc etc etc. By looking a 2-3 videos so far, I have a more complete picture, but I will try to document each phase of the process here to provide a more complete process.
Here is a general outline:
So far, the extra tools I am purchasing for this job are:
- Drain transmission, torque converter (if there is a plug on the converter).
- Drain transfer case.
- Remove drive shafts.
- Remove exhaust Y-pipe.
- Remove cross member for transmission mount.
- Remove transfer case.
- Remove transmission.
- Remove flexplate.
- Remove rear main seal.
- transmission jack: https://www.princessauto.com/en/detail/1-100-lb-low-lift-transmission-jack/A-p8667875e . It's pretty inexpensive, but if MJReynolds was able to get it out with something like this: https://www.harborfreight.com/450-lbs-low-lift-transmission-jack-61232.html , on uneven ground, with hardly a bleep, I think I can do it with the tool from Princessauto.
- High torque impact: https://bcfasteners.com/shop/milwau...ue-impact-wrench-1-2-pin-detent-with-one-key/
