Rear main seal leaking. Help
tank4x4_97
I recently purchased a 97 2 door 4 wheel drive tahoe. I believe I have a rear main seal leaking. Tried to stop leak stuff from the parts house seemed to slow I down but not stop it. How hard is this to change out ? Can it be done with basic tools ? I'm not a mechanic by any stretch but I try to fix things if I can without paying a shop to do it.
T
tank4x4_97
Thanks for all the responses. All the info was helpful.
NOT COOL
electro
Kitchener, ON, CAN
You'll definitely want a manual if you haven't really worked on that stuff before.
With four wheel drive you will have to remove both front and rear drive shafts (30min tops if you work) Then unplug and un bolt transfer case (pretty heavy, upwards of 60lbs. Id say)
Now you'll need a transmission jack. Unplug and unbolt transmissoneermachine and support with jack of course. back it up.
I think you'll have to remove exhaust piping from just in front of the cats.
Then you back the transmission up and access seal behind rear main seal cover.
Its definitely a chore for the beginner but SOO worth it! lol
T
tank4x4_97
Thanks for the info. I definetly will get a manual and I'll probably have some help. Just don't wanna fork out hundreds of dollars or more if I don't have too.
TheFuzz
Idiot Police
Spurbury, VT
NOT COOL
It's generally helpful if you read the forum headings before posting, and put your questions in the correct section for the year of your truck. This is the 07-14 section.
b18cls1
