This is kind of wierd. I purchased a 2003 Yukon XL 2500 4x4 last April. And i have noticed that whenever i put in regular grade fuel the engine will act up about 100 miles into the tank. It will go into Reduced Engine Power mode and throw codes for rear knock sensor - low voltage, throttle position sensor, pedal position sensor. Then after I clear the codes they will come right back until I put in mid grade fuel. Then it runs like a champ with no problems whatsoever. Does anyone know what could cause this? I have just put in the mid grade fuel and gone over 10,000 miles with no issues. I tries another tank of regular and the codes all came back?
Vehicle has 185K miles with the 6.0 Liter engine.
