H8 PVMT
- Joined
- Nov 30, 2009
- Posts
- 58
- Reaction score
- 7
Its been a while since I pulled the codes, I could be incorrect on the exact numbers but it's plausible that the cat is clogged up. I saw it since we moved, we moved from NC to Colorado - not sure if the altitude change did anything to the truck or not. My current thought is replace the cats since that has been a constant with the issues I've had and about the only thing I haven't replaced. lolThose codes are both for Bank 1, one is rich and the other lean. Still getting the same codes after replacing the O2 sensor or no more code(s)?
If the original sensors weren't bad, then they were accurately reporting that the exhaust is actually rich or lean. But, maybe a sensor was bad and reporting that the exhaust was lean. So the PCM unnecessarily richened the fuel mixture which sooted up the 275K-mile cat converter and the O2 sensor. The cat was then clogged and the sensor is partially choked with soot so now it's reading the exhaust as lean... Just a guess on a plausible story.
The conflicting codes both being for Bank 1 intrigues me.
