Reeee Dooooo!
bottomline2000
Dallas, TX
That leather works looks great.
I put carpeted mats in the Tahoe. Black rubber nibs on the backside hold them in place great. I opted to have the bowtie for the front mats. It is a 4 piece set.
Here is the link to stockinteriors.com, specifically the floor mats section
https://www.stockinteriors.com/floormat.asp?Itemid=5380&ModelId=595
The embroidery was $35 and only at the time came in black. I also ordered the interior carpet kit when I redid the interior so the mats and carpet are a perfect match and only 1 shade darker than the OEM carpet on the back of my 2nd row seats. Love the mats and the carpet kit.
View attachment 213254 View attachment 213255
Hate i didnt see this before messing with weathertech. I spent $40 just returning them..ugh..are those the plush cut ones? I only want the front 2 but it seems that is not an option..
Sent from my SAMSUNG-SM-T377A using Tapatalk
Fosscore
Yes they are the plush cut just like the carpet kit.
Ryan Buck
Ryan Buck
Mesa Arizona
It looks a lot better in person I promise.it looks like it’s ment to go there how good it fits. Do you have to pop that panel off the consul and then unbolt the clock and cut all of those little pinch weld off the back of it so that you can pull the wood face plate off of it in the little cubby box after that I took my Dremel and opened up the underside of the top lip so that the iPad can sink up in there That way the flap door above the ashtray still can function 100% without hitting it. And then I notched out the side so the cable can fit in there and it’s super tloud got but holds it in place. For a mount I just used one of my cases. I had a flap that covers the screen and I just cut it off then I trimmed the top so that it can slide it in there easier without having to cut too much of the actual plastic dash out. I’m going to put some double-side for a mount I just used one of my cases. I had a flap that covers the screen and I just cut it off then I trimmed the top so that it can slide it in there easier without having to cut too much of the actual plastic dash out. I’m going to put A strip of Velcro on the bottom just to hold it. But it is not necessary because that thing wedges and they’re hard-core. I also took some fiberglass resin and fiberglass mat and reinforce the corners on the inside just for added support but it’s not necessary just my OCD LOL and it is hooked up into my pioneer AVH see A strip of Velcro on the bottom just to hold it. But it is not necessary because that thing wedges and they’re hard-core. I also took some fiberglass resin and fiberglass mat and reinforce the corners on the inside just for added support but it’s not necessary just my OCD LOL and it is hooked up into my pioneer AVIC5200NEX with the USB cable into the port on the back of the radio so it connects and charges. The only thing that stupid is you can’t get Apple CarPlay on the iPad only the iPhones have it I don’t know why. But you don’t need it because everything is on the iPad. All I have to do is connect my mobile hotspot from my phone to it and it’s 100% function . Now I just need to get another iPad that way I can leave that one in there at all times. I’m also thinking about getting a Nother case and leave in the stream flap on it but just trimming it so that when I’m not using it I can fold it up to cover the screen Or I might just make a little cover out of fiberglass that pops in there because the reason I cut the flap off is it looks retarded hanging down while you have it open. If you would need any help let me know if you could send me your panel and I’ll cut it open for you.
Ryan Buck
Ryan Buck
Mesa Arizona
I finally got around to installing my Rockford fosgate o gauge power wire. it was like pulling a garden hose. I also swapped the wire to the back of the Alternator. That’s what the small wire is in the photo. I’m not sure what age it is but it’s teeny compared to the other two sizes. I took the four gauge run out of the truck and put a zero in. I can tell a difference this morning driving to work with the bas alternator. That’s what the small wire is in the photo. I’m not sure what age it is but it’s teeny compared to the other two sizes. I took the four gauge run out of the truck and put a zero in. I can tell a difference this morning driving to work with the bass. It hits way harder actually was hurting my ears not even cranked up that much.
B231FECE-82B2-4ED9-96AB-33ABED2C0CF9.jpeg 3F02DD43-6344-449A-93E4-38EC658EBD67.jpeg
Ryan Buck
Ryan Buck
Mesa Arizona
I have been busy with the stereo system in the Tahoe. Not much room under the captains seats to put stuff but I'm managing. Built this little amp rack to keep stuff looking cleaning. This photo is of the 10 farad capacitor and the Rockford fosgate 3sixty.3 CF66BB66-8B6B-499E-8D5D-EDA8A8F7E9A9.jpeg BF384340-6500-42ED-8C1F-49A735357D60.jpeg
drnahmias
