Remote start with factory keys (complete)
Nathan Morrison
Installed a Fortin Evo-GM4 remote start. You need the remote start and the flash link updater for programming. Follow the video below from Warmcarnow on YouTube for install.
I had everything installed but had to call customer service to realize I had to click the setting for "start on lock-lock-lock" in the programming software from my computer.
I was able to start it recently from my 4th story hotel room and 300ft away to the back row of the parking lot with a factory remote.
https://www.crutchfield.com/p_938EVOGM4/Fortin-EVO-GM4.html
https://www.crutchfield.com/p_938FLU1002/Fortin-FLU-100-2.html
Ilikemtb999
Denver
I installed a flash logic brand remote start that was $100 on eBay and was as simple as removing the lower column piece similar to your. You hit lock 3 times to start it. No programming and works flawless with the stock remotes.
Nathan Morrison
Nathan Morrison
That's pretty nice it must be pre programmed.
I thought I was getting this one so I could add a long distance kit later but it works far enough.
09Tahoe4Now
Can you @Ilikemtb999 give a link to the eBay seller for the flash logic unit you purchased? How’s the distance for remote starts? Thanks in advance for the information.
Ilikemtb999
Denver
trailblazer
The Fortin and Flashlogic kits can have aftermarket remotes added that substantially increase the range; you’ll need to get the antenna kit too. I have the factory remote start and the range sucks. I’ve installed both the Fortin and Flashlogic kits in various vehicles (super easy to install) that use the OE remotes but the range usually sucks.
Sourdeez
The video is no longer available, you just take off the plastic knee bolster piece under steering wheel and connect the harness?
joo3yy133
