Remove factory amp to install aftermarket...
yates ™
Resident Apple hater
Iowa
You need to forget about the subs and focus on the problem you are having. I told you exactly how how to bypass factory amp.
M
misterniceguy
Subs forgot about.
So I should run new wires to all the existing speakers to bypass the stock amp?
yates ™
Iowa
I would because sounds like it has problems. One more thought did your buddy cut any of the factory wiring?
M
misterniceguy
The factory wires looks to all be intact. When I installed the headunit, I just used the harness that it came with and it was pretty much plug and play. As far as I know, the wires are all as it was stock.
I'll look into what kind of wires I need to bypass that amp.
yates ™
Iowa
Are you planning on running an amp to your door speakers?
yates ™
Iowa
Go radio shack buy a spool of speaker wire and get to work :Handshake:
wiser1
