Mudsport96
Well, how goes it?
Yeah, thats kinda the problem with newer stuff. I did cam headers and ported the intake and heads on my Nova and all it took was a distributor spring kit and a few tweaks to the carb and it was road ready.Fixed exhaust leaks. Just took off throttle body and cleaned it and replaced with new gasket. It was definitely in need. Black bear said to clean it ,, may be the problem on why it won’t want to idle. I should say it does idle I just can’t touch the throttle. It will almost die then bounce back and idle around 800 or 900 rpms. After shutting it off and restarting some times it’s ok and some times not. Retightening header bolts if I have to. Just keeping a watchful eye on everything. Will refill air conditioner Friday. I will probably make an appointment with black bear to do the ride along. I think some of the problems is that I’m not used to driving a hot rod, so i will be on the learning curve , trans shifting etc.. BB is not far maybe five hours. Need a road trip.
Going for tune today. Put it through its paces on the way over towing camper trailer. I’ll post results after tune.Have you happened to get a follow up tune with the scan cable? Very interested in your build, and what all do you want to do to the transmission?
Oh hell, another islander. You'll be seeing my Bentley cruising the island soon. Just started resurrecting her. If you need the big bad scanner, get in touch. I carry it with me everywhere.Part Number: 059-HP97 From JEGS. I have 220000 on the hoe now, want to stay ahead of any trouble and replace it now. Looking for options .. advice. No core return. Don’t really want to strip down the motor and rebuild . I realize it would be cheaper but don’t want the down time. Plug and play right?
An RV grind cam is perfect for one of these. With good exhaust and a decent airbox, they pull pretty well for a shrimp of a motor. I'll be installing a 6.0 when this one dies.If I read your coordinates correctly you're in Chilli? I used to work at the Caterpillar plant in Mossville and went to Manual HS in Peoria. Many moons ago...
