Request for Parts Help - Fog Lights
blackout07
Beaumont, TX
Please do. Although I measured the fogs in my truck vs the openings on the tahoe and there seemed to be around a 1 inch difference if I'm not mistaken. I was hoping that they were the same. Are they not a flush mount on the new
Tahoes.
Also post some pics of the lamps installed. Thanks,
dochmurdoch
Yeah thats what i thought too. My parents have an ltz so i double checked. when looking at the fog light all the edges are hidden by the bumper trim. I will try and get numbers up tonight but my wife is taking me to dinner and the movie Fury tonight so it might not be till tomorrow.
ebelp
Any update on those part #'s? Pretty pleeeease?
---------- Post added at 10:38 AM ---------- Previous post was at 10:32 AM ----------
Forgot to ask...did you order the chrome trim piece that goes right above the factory fog light openings? Please share that part number too if you have it, thanks!
dochmurdoch
Brackets Part#'s 22936482, 22936483. Lamps Part#s 22872762, 22872763.
I have lost the part numbers for the switch and harness, I am still looking. I did not get the chrome trim piece. The LT's that have the luxury package do not have the chrome. LTZ does. The bracket is plastic, place the lamp inside the bracket and it just clips in. I had to remove the inner fender well to get behind bumper. Remove the plastic inserts where the fog lights go and replace with the new brackets with the same screws you just took out, its that simple.
---------- Post added at 05:25 PM ---------- Previous post was at 04:59 PM ----------
Just found the switch part #. 23187804. It is the same switch found in the 2014 chevy silverado. They look the same, this one just has the fog light switch built into it.
blackout07
Beaumont, TX
Thank you sir. Just ordered wheels and this will follow.
ebelp
Thanks for the info! Where'd you find the lamps for $40?? I only see them on eBay for $80-90 EACH.
Also curious what wiring harness you used. Just a universal relay harness?
dochmurdoch
Part numbers 25883246 and 25883245 also work for the fog lights. These are the discontinued numbers from chevy but they still work. I have not bought the wire harness yet, parts guy told me it wouldn't work, harness also has wires for the park sensors in the front bumper and said it would cause problems. I lost parts number for harness, next time I'm at dealer I will ask again.
ebelp
Thanks again. Will the brackets you mentioned attach to these?
I've also been questioning how involved it would be to install the OEM fog switch. Others have said it goes through the ECU and if it somehow is tied into the park sensors, it sounds like it could get pretty complicated. I have a feeling that using a universal HID wiring harness hooked up to a universal push-button switch might be the easiest option. As long as the fogs turn off with the ignition, that's all I care about.
greg_tahoe84
This is why when I looked for my Tahoe LT I insisted that it had a Luxury package. Safety features, fog lights, etc. It was a pain to find one with the exact features but I eventually found it.
TwiztidFate
