retrofit or not?
DenaliAK
Colder than you
Alaska
Thanks, I'll try to do a write up with pics, but we'll see how much time I end up with to work on it. Having another guy help me, too, so I can't take the credit. He knows what he's doing and I don't, basically....lol. I know a lot about the lights, but have never actually done the hands-on part, so it'll be good to learn.
What color are your bulbs? I like the light from those. And why do you have what appears to be a three-tiered cut-off? Kinda funky. Looks like something is not lined up, or it's just a different cut-off then I'm used to seeing.
R
rigo_jones
going against
DENVER mexico
i dont know the color temp of the bulb i bought them locally for $25 i was told 6000k but look like 4300k. IDK. as for the funky cut off i dont know what you are talking about. what is three-tiered cut-off?? i might just buy some depos man. 1 thing i dont like is how short the projection is. it frustrates me that i cant see far. ive been looking at the af-r projectors but i might put my next retrofit on hold for now... unless your looks badass i will copy you lol...
this is what i dont like.
and this is what i want.
DenaliAK
Colder than you
Alaska
In the last pic, against the wall, your light appears to go in three steps, from left to right. Typical cutoff is one step. The confusing part is that you have two headlights, and the cutoff in the middle, the step, should line up from each headlight so they overlap. If you cover one headlight, you'll see the cutoff from the other. Then do the reverse, and you'll see the other cutoff. The driver's side should be a step lower then the passenger, but the cutoff point for each individual light should line up with the other on the wall. You can actually do all of this and mark it off. It's reallllly hard to explain this w/out pics.
This is a random google'd sample of a good cutoff, what it should look like in the perfect world:
Someone on here, might be Max, don't remember, has recent pics of an excellent cutoff in his jeep. This is an excellent link from another forum on how to align your headlights properly (HID or not): http://legacygt.com/forums/showthread.php?t=54740
Anyway, I think you could correct your alignment by either lowering the passenger side or raising the driver's side beam a little. Could be wrong, though, in which case you just have funky lights....lol. That light ouput you want, from that last pic, is pretty amazing. Fairly sure that's with high's on, though, but still....
I'll keep ya'll posted on my project.
DenaliAK
Colder than you
Alaska
Freakin' Columbus!!!
I was waiting all weekend for my parts to get in only to realize it's Columbus Day and the good ol' USPS is not operating today.
Aaaarrrgghhh.
Waiting on: Depo headlights, Morimoto D2S 4300K HID bulbs, Matsushita Gen 3 OEM ballasts (stock parts on Infiniti/Nissan vehicles with HID's), wiring harness. Already have TSX clear-lens projectors.
DenaliAK
Colder than you
Alaska
All the parts are finally here. Took the headlights a little longer then I liked, but now the work can start. These are the headlights I'm going with:
Completely removing the projector and replacing it with a TSX clear lens projector, then installing HID's. Should have great light and cutoff when it's finished.
R
rigo_jones
going against
DENVER mexico
damn nice. i get my depos on Wednesday but what i dont like is that they are chrome :/ but cant beat the price of $50 new on ebay. hey bro are nissan murano projectors good? some one beat me to the tl headlights but i found some muranos but dont know if they are worth retrofitting they are of an 04 or 05 nissan murano.
DenaliAK
Colder than you
Alaska
Honestly have no idea on the Murano's. Never heard anything about them one way or another, which probably means they aren't the first choice for a retrofit. If you're going to retro, you may as well make sure you are using quality projectors, ya know?
Ok, so the Depo projectors are removed. They came off pretty easily, actually, and with no baking required. They are screwed in and siliconed, so you just remove the screws and then kind of scrape the silicone out and pry the projector off. No point in baking the whole thing apart if you don't have to.
The TSX projectors should fit on there with only very minor modifications. It's almost a perfect fit. This shouldn't be a huge project.
Will have more info and hopefully pictures once things are closer to done. I will also have two sets of Denali headlights and a set of Depo projectors (just the projectors) for sale when I'm done.
R
rigo_jones
going against
DENVER mexico
cool thanks in going to see the murano headlights i found for $100 obo. but i might just go with some tsx like you or the fxRs.
BrancoRST
