Say what? Welcome to the forum. The other members that responded must speak Tagalog. I am old. You have to help me, but I do understand that by what you said, and both members gave you great advice. If they went out at the same time, you did not say-right?, then is likely the master switch.Have a 04 tahoe right side windows not check fuse relays need direction
I know this an old thread, but I did the same thing with my driver side switches. Alcohol and q-tips. The contacts were definitely dirty and this did the trick. Several videos on you tube. Saved me @ 130 bucks.I may be a little late here but my switch for the drivers door wasn't working very well. I removed the switch and completely disassembled it and cleaned the circuit boards and rubber membrane with rubbing alcohol. The boards were definitely dirty and had a kind of grimy feel in some spots. Once I put it back together it was working fine. Lsx Matt on YouTube had a video about doing this too.
