Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
I haven’t given up on the hard lines, that’s a good idea Tony. I think the bender I have is for advanced users lol. I did get one of the rear height sensors installed, I just need to do the final mounting and adjustments. I can just copy it on the other side. And since I didn’t feel like I got enough done today, at 3:00 I decided to make the fuel line and install it. I figured it should take an hour or so. :) So I disconnected it from the fuel rail and it was already cut off at the tank so I started removing it from the rear forward. I got up to around the trans and started to cut it with side cutters but it wasn’t aluminum anymore and I couldn’t snip it, and then right ahead of that found some electrical device attached. Oh shit.. I was planning on just installing AN fittings with quick connects at each end but obviously that wasn’t going to work, but luckily the spot I tried to cut it wasn’t too close to that device that I couldn’t connect to the line there. I remembered that 1/2” PEX clamps are perfect for this hose size. I tested it on a scrap piece of tube and it was unbelievably tight so I used 2 of them just to be sure. I tried to start the truck and nothing, didn’t hear the fuel pump run. Then I remembered the fuel pump module was unplugged. All is good, no leaks.
FF91E008-7945-4E3C-9F9A-118C2D3096FB.jpeg 034CD85B-2597-4058-B3B9-3B18532D2E4A.jpeg
Bowzer
SoCal
This Imperial one, recommended by guys who do this for a living. The instructions give me a headache lol.
View attachment 241824 View attachment 241825 View attachment 241826 View attachment 241827
Nice bender. Used these extensively for refrigeration and controls tubing. I suggest starting with 1/4” soft copper before moving on to more expensive materials. This is becoming a lost art especially with the obsolescence of pneumatic controls.
Truck is looking good too!
I finished up the tank to manifold line and did the right rear bag line. That one seemed simple but I kept getting the up/down angles backward so it took me 3 tries and 6’ of tube instead of 3’. The fronts are gonna be hard but I will be doing them in 2 pieces each since the 6’ tubes won’t reach anyway. That’s just one union each. I plan on working from each end to the center. I also re-loomed the entire rear stock wiring harness and remounted the manifold higher due to how far up the driveline comes when it’s fully aired out.
Edit: the lines still need clamps where they cross the frame, I’ll do those all at once.
88370D1F-170A-4DF5-9ED6-7C0007A3352A.jpeg 5E8EFDD0-56FB-4E9C-8E71-8B0407B51197.jpeg 33037FD1-DC0E-4B15-A688-5655FA2F9DC9.jpeg 1F91B3E7-D726-4258-BEEA-4D10E33FDD8F.jpeg 7236046D-5882-4A07-BD5B-D74D066666F3.jpeg
The new mh1 reflect bowls arrived yesterday and even though I asked the rep twice on the phone when I ordered them if they included the big hex nuts to mount them with since he told me I’d need to cut those off with a Dremel, they didn’t come with them. These took 8 days to arrive even with 2 day priority mail so I’m pretty unhappy and luckily they were closed when I tried to call, so I sent them an email. Good thing this isn’t my DD. Anyway I find it strange these don’t say Morimoto like the originals. Maybe they’re knockoffs? They look good though and I’m liking the shrouds in black. And here’s a look through the etched lens from the back side.
56A84392-5618-4509-B11A-C30F0CC29632.jpeg 64740070-FA62-4CBB-98D6-C863AD2522B9.jpeg image.jpg
ishwood
