Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
Trying to keep everything as clean as possible. There’s a lot of stuff between wiring, relays, air lines, filter, etc. I am shortening or lengthening the harnesses as needed using soldering and heat shrink so there isn’t a bunch of extra wire anywhere.
C070A4E7-79C3-4424-B6BA-573E9CBFBEC9.jpeg B6F136F0-3085-4D29-9625-B459FFCC421A.jpeg 512BA1EC-BAD9-4273-B371-67BA8F77A8C9.jpeg
The rear is complete- hard lines, sensors, harnesses, compressors, filter, etc. Here’s the rear height sensors with the suspension fully aired out and fully aired up. The arms look close to the bottom of the frame in the one pic but that’s when it’s aired all the way up ( which I only do when jacking it up) so the frame is way off the ground at that point, and when it’s laid out and the frame is on the ground, the arms are at the upper position.
6BF665E7-84AE-4DB0-B986-3710F19F19AA.jpeg ADCE7771-A70D-4EC7-A0A7-21D7E21A0542.jpeg 0DCC8D94-37FA-4CA6-940C-71A77AE32D56.jpeg
Front sensor mockup. I worked quite awhile before I came up with a location that didn’t interfere with the steering or bags and was outboard far enough that there was enough travel to be accurate. This is the spot. I ordered some clamps that will go around the control arms that I can mount the rod to, Amazon will deliver them tomorrow. I’m gonna sleep on it tonight just in case I’m forgetting something before final mounting and adjusting tomorrow.
The one on the driver side was definitely the hardest yet. It had to go around the charcoal canister but the worst part was just getting it into place after I got it bent into shape.
4BFBE3F2-E0C8-49B7-9533-DCB014DF7A83.jpeg 4644DFA2-C4F3-479B-B4FC-068B3CB644B1.jpeg C036B215-6BA1-4E02-A634-7D26AA14F56B.jpeg EA841687-F11C-4C6F-BC3C-20B5B236BFB2.jpeg FEDCBA6E-DE3D-4B21-A402-0CDF35770428.jpeg
wjburken
Eastern Iowa
View attachment 241999 View attachment 242000 View attachment 242001 View attachment 242002 View attachment 242003
Looking good!
Reminds me of the time I had to replace the brake line that ran to the rear on my 1976 Impala in the parking lot at college. Bought a number of lengths of pre-flared brake line and a cheap tune bender.
ishwood
