Rough idle at start up
Tdub
When I started the truck this morning it started right up but began to idle a little rough and dropped to about 500 rpm then back to a 1000 and back to 500 an continued to idle rough for a few secs. I backed it up to park in drive and seemed fine. Is there some sensor that could do this or would a fuel filter be the culprit? Please don't say fuel pump! It seemed to snap out of it.... and drove fine all 250 miles yesterday.
Narco
Atlanta
have you seafoamed it? my idle leveled out after i did mine
puckhead
CO
Mine did that once and I was told a piece of carbon might have came of the EGR valve and blocked something from closing all the way. Never happened since though
Tdub
Tdub
So help me here guys where do I find some of these sensors that your talking about?
BOSS
The People's A D M I N
Dallas
These two parts are what connect your engine to the outside air :)
The MAF sensor is connected to your air filter box. Air comes in through the box, through the air filter, through the MAF sensor, and into the throttle body on the engine. The MAF sensor has a screen attached to. Read the instructions on the MAF cleaner can and you're good.
Follow the air tube from the MAF sensor to the engine to find the throttle body. When you are cleaning it, open up the flap and spray/wipe with throttle body cleaner.
B
Daddyyukon92
