Rough idle at start up
blueflamed03
Oklahoma
TB and MAF are where intake breather comes from passenger side. you will take MAF off to get to the throttle body. You can purchase MAF cleaner, it's a spray at any NAPA or parts shop. Then use like B12 Chemtool to clean TB, inside and out.
Tdub
Tdub
Cleaned the MAF and then ran some sea foam in the gas and poured a little in oil. It seemed to idle a little better this morning, little choppy still but better. This could possibly be because it ran for a few late last night so it hadn't but shut off as long as the other day when it was acting up.
Rivieraracing
Be sure to hose out the TB like mentioned, that was the best fix for my idling problems by far! Seafoam sells Deep Creep that works great too!
Tdub
Tdub
So you just spray it all over the TB then or?
Rivieraracing
Just take your intake tube off of the TB and spray the crap out of the inside of the TB
rigo_jones
going against
DENVER mexico
:slap:
Nooo! dont do that. remove it its only like 3 bots or nuts. the AICV (air ide control valve) is part of the TB. remove it and clean it good with brake parts cleaner. do it while the truck is cold.
Rivieraracing
:slap:
Why not, just offering the "easy fix" to see if that helps out!! Also, I'm not sure if I would spray brake cleaner in there, may not hurt but I would feel better spraying TB spray, the stuff that is meant for this application!
rigo_jones
going against
DENVER mexico
because it wouldnt make a difference since the AICV is located inside the TB. aether works i always use brake parts cleaner it doesnt mess up plastics.
WHITEOUT
Dont Hate-Appreciate
Phoenix
1+. I use brake parts cleaner for ALOT of parts. It's very versatile. It dries quick, and cleans off residue like no other. Not saying TB/CARB cleaner isn't great, but brake parts cleaner also works magic. just my 2c
WrenchGuy
WrenchGuy
Just cleaned mine. Much better and was having the same issue.
I had minimal tools around but did pop it right off (3 nuts 10mm)
Do it this way because you'll never get it as clean. When I get to more tools I plan to remove and clean all components of the TB.
Great improvement for what I had tho.
Thanks everyone.
Daddyyukon92
