Got a call back from the dealer. YOU GUYS WERE RIGHT! It was the intake manifold gasket. Since I live in an apartment and it's below freezing right now, I asked them to replace the gasket.
Also, they said that the wiring harness for my defroster grid (the harness is located in the front somewhere??) had a bad wire. They said that the harness has been discontinued by GM/Chevy. They're going to hit up a boneyard to see if they can get a new harness for me.
The last thing was the brakes. I have been getting severe pulsing in the brake pedal during braking. Apparently, this is due to the rotors being warped. That's odd to me because I replaced the rotors a couple years ago. However, it could be that because I've been traveling to the mountains so often that coming down heats them up quite a bit. They said it's not a safety issue, just more of an annoyance. I asked them not to do anything with the brakes as I'll get new rotors/pads during the next service.
Guys, thanks so much for your help and advice. You were spot on, and just as bottomlin2000 said, there's so much info on this forum. Thanks!
