Rough idle only in cold weather? Please help
mattt
Check your oil cooler lines.
Oil cooler....as in engine oil cooler? Not sure 1500 Tahoe's had that? I know the oil cooler block off is in place right above/in front of the oil filter mount.
rockola1971
Indiana (formerly IL)
Theres only one oil in a Tahoe and that would be Engine Oil. Both of my 2003 Tahoes have an oil cooler and so does my 2005 Yukon Denali.
mattt
Ok, can someone provide some info on where the engine oil cooler is located and where the lines leave/enter the engine block? I have yet to locate or ID an engine oil cooler on my '04. I see trans cooler, and ps/hydroboost cooler only.
Larryjb
Thank you! Looks like the TSB won't apply to me since I'm in an '04. Thanks again.
Now if I could locate the source of the dirty top side, have the dirty bottom side too, but it's wet and drippy down there....I'm thinking rear cover and/or oil pan.
It may still apply. The TSB I referenced was for my 2002 Tahoe, and was issued in 2002. I would still inspect your knock sensors and if they're still in the valley cover plate, place a bead of RTV just as in the 2002 TSB. Sometimes these TSB's aren't updated to include all relevant years.
Larry
bottomline2000
Dallas, TX
I believe the oil cooler lines enter/leave just above the oil filter. If you just have a block off plate there then u do not have an oil cooler.
Sent from my SAMSUNG-SM-T377A using Tapatalk
mattt
Would you mind posting a picture or pictures of these oil coolers & connections to engine that your 03 and 05 have? I'd love to see what that setup looked like. Thank you in advance.
mattt
Any chance you could post a picture or two of the oil cooler that is on both of your Tahoes? I'd like to see what the factory set up for an oil cooler looked like. Thanks in advance.
mattt
Thanks for that link. I was interested in seeing what Rockola1971 had on his Tahoe's. I've never seen an oil cooler on any Tahoe, which is why I asked him.
The 6.0 oil cooler is common. I've had it on my old 6.0 2500HD truck. Not saying a Tahoe didn't have it as an option, but I'd like to see it and know the RPO code that adds that option. Hopefully rockola1971 will post up.
Andreste22
