Roughy Boggy Idle....
derekjames
Hey all!
Ive got a 2009 chevy tahoe with the following going on:
1 CEL present for heater circuit.
Very rough idle and serious shaking at higher RPMs in the Neutral position.
Very boggy, almost like there is no power ... Please HELP!!!!
B-train
What's the code number?
A heater circuit code is usually O2 sensor. If an O2 sensor fails, it will default back to an OEM base map that will allow the engine to still run......but not excellent.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Yep, I had a great running 2005 Tahoe, the one I currently have, and then one day, the CEL pops on and it would not idle worth a crap at a stop and was sluggish taking off. Changed all 4 sensors and problem solved. IMO, the oxygen sensors are maintenance items. Miles on the engine? High rpm's at highway speed problems?
Fless
Super Moderator
Elev 5,280
The heater code, if it's for an O2 sensor, will indicate which bank (side) and whether upstream or downstream. Once you document that, if you're adventuresome you could switch/swap the same position sensors from side to side. First, though, check the heater fuse for the side that's having trouble. Likely it's a defective sensor, but you could also load test the circuit to make sure it's live and handles the necessary current, before throwing parts at it.
bobarich
