Besides the absolute compression value, all should be within about 15% or so of each other. Maybe even as much as 20%, but that's getting borderline.
Did compression check on one side of the engine,Besides the absolute compression value, a
And thats the harder side of the engine to do. I would say you have some blow by going on by those numbers. Its within spec cylinder to cylinder (barely), but those are some pretty low numbers.
Hopefully you got genuine AC Delco injectors. Amazon is notorious for selling knock off/bogus car parts, especially spark plugs. You really should make sure--as stated above--you buy genuine parts.Update..!!
Got a set of injectors on Amazon (prime) so I could get them quick,and cheap and installed them today.
Most of the misfiring cylinders are not misfiring anymore, I have my scanner which shows each cylinder, how many misfires it generates. I have only 2 cylinders on bank2 that are misfiring a little bit. And one cylinder on bank1 that is also misfiring a little. Bit
I believe those little misfires are due to the bad spark plugs because they were dark when I checked compression.
Now im about to order, new coils ,new cables,new spark plugs and new injectors, maybe a good name brand
