Scored a LQ9...but have questions
03TahoeZ71
Minnesota
So I got a LQ9 for $300.00 from a buddy. It's out of a 04 Escalade and had a 106,000 on the clock. So here's the deal the owner replaced it because it was making one hell of a noise. However my buddy found out when he got it that the serpentine tensioner was toast.
So the motor appears to be in good condition. He pulled the heads and and everything was in good shape except there was a slight lip at the top cylinder bores. Everything turned over nice, no shavings ,oil was real clean,cylinder walls were in good shape.
I was thinking of getting push rods, a gasket kit and new head bolts and running it the way it is. Or am I being dumb? Should I at least do a full stock rebuild? I'm thinking this thing has a lot of life left before it needs a rebuild.
Thoughts?
Administrator
If it was me I'd just do the rebuild not and save yourself a lot of time and money in the future by doing it all right the first time rather than putting it all back together with a known issue.
Btw, nice score on the motor man :High 5:
blueflamed03
Oklahoma
I think you should send to me, not worth rebuilding........j/k LOL. Nice buy
I say while its out, new bearings and re-ring it. Then at least you know.
Travieso
Boooooooost !
Los Skandeles, CA
i would rebuild for piece and mind even though these motors are pretty strong i would rather have piece and mind..
if it was me i would bore it out and put a cam while it's out.
smurphy80
I def agree...rebuild it as long as its out. The added money now will be well worth the savings down the road and heartache. Like above, atleast then YOU KNOW for sure.
Z-56 Hoe
What do I do????
Houston
Rebuild / freshmen up!!!! While out bore and stroke and do a cam and some head work. Spend the money now and have peace of mind for another 8 or so years
03TahoeZ71
Minnesota
Can you re-ring without doing a complete rebuild? I'm assuming run a hone on a drill to get the crosshatch pattern and then put the pistons back in with rings and bearings.
Administrator
I'm liking how you're thinking :D
THE-HOE
Pittsburgh Pa
If your on a budget I wouldn't even worry about doing bearings. A lq9 with just slightly over 100k on it still has lots of life left. If you have some money saved up then go ahead and do it right and replace some stuff. IMO do a cam and valvetrain while you have the engine is out of the vehicle.
Roscoe2352
