Sea Foaming, Power foam, and the like fact or fallacy?
G
Gordy
Seems most of you are talking about adding it in the tank. I should have been more clear in my post, as to the fact I do not have a problem with injector additives to clean injectors, and lube upper cylinders. Sorry for my vagueness on that part. The quality of fuel is sad anymore, and only going to get worse.
There is a lot of talk about people getting poorer gas mileage these days thinking there is problems with their vehicle. When it is more than likely the quality of fuel burned in it.
If a pump says 10% ethanol content that's 2.6 gals in a 26 gallon fill up being straight ethanol. Burning straight ethanol always produces poorer fuel mileage. With that being said obviously you are going to get less miles per gallon with an ethanol based fuel.
My original post was more oriented towards intake cleaning, and engine flushing. I just think that you are playing Russian roulette doing these procedures. For the cost of the additive compared to what is maybe gained, or could be lost (an engine).
Kudos to those of you who have had no problems using it in the intake, and for engine flushing. Through research on the web I have found as many dont's as do's in engine flushing. As for the intake cleaning I will stick to a disassemble cleaning procedure its a sure thing visually knowing the deed is done.
My tahoe runs like a top at 125k with out doing any of this so why bother with the risk. Mileage gain would be a nice asset though.
For those that are gaining mileage of 2MPG with a can of seafoam which I have seen reported. Thats basically getting you an extra 3.47 gal a tank compared to the old mileage. So these days thats about 11.99 for a 6.99 can of seafoam investment. If you have a 26 gallon tank, and you were getting 15mpg, and now get 17mpg thats an additional 52 more miles per tank divided by the previous 15mpg is 3.47 gals. Todays gas price is 3.46 in my neck o the woods so 11.99 for a 6.99 investment. Another way to look at it if you subtract the cost of the seafoam from the dollars saved per tank you are saving 5 bucks every fill up. Thats not bad if its consitent performance.
As for the 2 cycle oil I tend to think its probably about 38 bucks a gal. for the pennzoil synthetic, or 30cents an ounce. Way cheaper to get 2 more miles per gallon like about 1.50 to treat a tank at the 1 oz per 5 gal ratio. Or 5 ozs for a 26 gal tank if the price per gallon of oil is correct. So your return sky rockets to 10.49 buckos per tank. Thats IF you get 2mpg increase. I have read where some stated 2% increase which is way less.
I think I will give the 2cycle a try.
Gordy
chip
Tampa
What a great thread!
To the guys running the 2 stroke oil: Why don't you just use Lucas upper cylinder lubricant? It does the same thing, but it's actually made for 4 strokes and you can't "put too much in".
Also, if you want to make a huge cloud of smoke while cleaning the intake, you can use tranny fluid.
Physh1
Costs way more per treatment. I can use the Penzoil in every tank, get 2mpg more, & save money. Cost per treatment is way lower...
Cameron
Physh1
i have tried 1oz per 5 gallons which is a little thin, i have tried 1 oz per 4 gallons and it didnt seem to make a difference so i am sticking with 1oz per 5 gallons
As long as your somewhere in that range you're a-ok. I did 1oz per 4 gallons for the first few tanks than thinned it.
Cameron
smurphy80
I have also been doing the two-stroke oil in my rig for about the last 10 tank fulls, while its hard to judge and increase in mileage (because its winter and temps are going up and down all the time) I have noticed my fuel pump sounds much happier as well as much less piston slap in the cold cold mornings. My truck too runs like a top with 125k on the odometer, and I can't wait to see how she runs once the temps warm and stay consistent.
G
Gordy
Cameron
+1 Lucas is about 2.17 a treatment, and pennzoil is 1.50 if I got the price per gallon close.
Actually the seafoam bottle (Pint size) says it treats from 10 to 25 gal. so there is not a very concise science to its use. So My figures are skewed a bit on my thread. At 6.50 a bottle you would need two bottles to do a rich 25 gallon treatment thats if two bottles or a quart of seafoam has the same effect as 5oz of 2cycle. Thats pretty steep to run in every tank.
---------- Post added at 04:36 PM ---------- Previous post was at 04:27 PM ----------
Also, if you want to make a huge cloud of smoke while cleaning the intake, you can use tranny fluid.[/QUOTE]
Seriously do you really think its doing anything the engine will benefit from other than some upper cylinder lubrication short term. The smoke show is just a side effect of burning the oil not the carbon. :emotions122:
Gordy
smurphy80
Im using the Evenrude 2 stroke oil in a 16oz bottle that costs about 3.50 a bottle, at 4oz to 20 gallons, im running about 87cents per tank.
Physh1
1 gallon of Penzoil = $38 @ West Marine
1 gallon of Penzoil = 128 oz...
1oz = $0.30
1 tank worth is 4-5 oz of Penzoil = roughly $1.20 - $1.50 in added cost...
If I'm saving 2mpg...my fill ups are 20g
20g x 15mpg = 300 miles
20g x 17mph = 340 miles
40 miles = 2.35 gallons @ $4.00 gallon
I spend $1.50 more per tank BUT end up getting a $10.00 value in better gas mileage...
$8.50 savings per tank...not bad at all...
Cameron
pistolpetem9
