Seafoam
Redhoe01
The BDG
Forney, TX
So adding this to my tank will clean the injectors? In the oil will clean the crank case? What does it clean if you use the vacuum line at the rear of the engine? Manifold maybe?
cam3439
Yes. Yes, crankcase and anywhere the oil gets to (including the upper valve train). Try to put it into a vacuum line that will allow the seafoam to be evenly distributed like a vacuum line that is in the middle of the manifold (like the PCV valve line). And it should clean the inside of the intake manifold, intake ports, and intake valves. You should be good.
highrollin113
highrollin113
Undercover
Edmonton, Alberta, Canada
DESIGN
North Texas
It only cleans the injectors if you put it in the gas tank. If you suck it through vacuum line then it cleans the carbon buildup in the intake manifold.
DenaliAK
Colder than you
Alaska
I wish someone else on here was in Alaska...I need someone to show me what the hell the vac line is....
I can, however, find my own gas tank.
:D
Tribalbreak
WARminster PA
just my 2cents, i seafoamed my 03 Denali that had no previous problems, within 2 days i was replacing o2 sensors... haven't done it since... tried it on my wife's old 97 Honda prelude... same thing replacing o2 sensors... so for me i wont put that stuff through my vehicles anymore... i always herd good things... but experienced nothing but problems...
DenaliAK
Colder than you
Alaska
Hmm.
If it ain't broke, don't fix it, right?
I think I'll hold off for now. The last thing I need is car problems.
Reyes1987
