Service engine light w/ new engine???
willua11
willua11
Alabama
Cool. I know it failed b/c it didn't heat up in quick enough. THanks.
willua11
willua11
Alabama
does the catalytic converter have to be cold when i change out the O2 sensor??
purple 'hoe
Green Bay, Wisconsin
I've nicked my hand on hot exhaust parts, I sure as hell would not want to touch and hold it when it's ~500 degrees. So yeah, do it when it's cold.
arb905
So, why didn't you replace the catalytic converters and oxygen sensore when you replaced the motor?
arb905
If your motor went bad then its possible your cats and sensors were damaged in the process. I continued to get a CEL after replacing my motor, that is until the cats and oxygen sensors were replaced.
And the catalytic converters and oxygen sensors are usually only good for 100k miles.
Kinda like changing your oil but not changing the oil filter.
neilreuben
