service history from vin#?
doubletapdrew
Looks like no history, just the PDI. However Hertz might do all their service in-house. Only GM dealers will put stuff in warranty management
Vehicle Information
VIN: 1GKS2MEF1CR196459 Model: TK10906-2012 YUKON XL 1500 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 50 - FLEET
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Vehicle has no current record of required field actions.
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: EXHMG28L XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Select State Component Lty Wty 12/10/2011 9 MI 12/10/2018 70,009 MI
Emission Select Component Ltd Wty 12/10/2011 9 MI 12/10/2019 80,009 MI
Corrosion Limited Warranty 12/10/2011 9 MI 12/10/2017 100,009 MI
Bumper to Bumper Limited Warranty 12/10/2011 9 MI 12/10/2014 36,009 MI
Powertrain Limited Warranty 12/10/2011 9 MI 12/10/2016 100,009 MI
Emission Limited Warranty 12/10/2011 9 MI 12/10/2014 50,009 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
12/11/2011 A96459 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
doubletapdrew
Could you help me out with VIN: 1GNSCBE06DR236052 ?
Here's what its showing:
Vehicle Information
VIN: 1GNSCBE06DR236052 Model: CC10706-2013 TAHOE 1500 2WD
Type Number Original Nbr Description Release Date Status
Noncompliance Recall N120331 12331 STEERING COLUMN LOCK ACTUATOR GEAR 12/24/2012 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: R018N24J XM Status: Active
Bumper to Bumper Limited Warranty 12/06/2012 9 MI 12/06/2015 36,009 MI
Corrosion Limited Warranty 12/06/2012 9 MI 12/06/2018 100,009 MI
Emission Select Component Ltd Wty 12/06/2012 9 MI 12/06/2020 80,009 MI
Powertrain Limited Warranty 12/06/2012 9 MI 12/06/2017 100,009 MI
Service Contract
01/08/2014 3398216 ZREG----Regular Vehicle Transaction Add Credit 3422440 - Mobile Telephone Microphone Replacement 18,695 MI
01/08/2014 3398216 ZREG----Regular Vehicle Transaction Full Debit - Reversal 3422440 - Mobile Telephone Microphone Replacement 18,695 MI
01/08/2014 3398216 ZREG----Regular Vehicle Transaction 3422440 - Mobile Telephone Microphone Replacement 18,695 MI
01/19/2013 00001885443 ZFAT----Field Action Recall V2734 - 12331 - Inspect Steering Column - No Further Action Req';d 875 MI
12/07/2012 A36052 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
Fink117
Could you do mine as well drew? 3GNFK16397G131680
doubletapdrew
Vehicle Information
VIN: 3GNFK16397G131680 Model: CK10906-2007 SUBURBAN 4WD 1/2 TON
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Service Update Bulletins N060162 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 12/12/2006 Closed
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Service Update Bulletins N070007 07007 SERVICE UPDATE - REMOTE KEYLESS INOP/BATT LOW-GMT900 ONLY-*EXP W/BASE WARR* 02/06/2007 Closed
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Branded Title
Warranty Block
Service Information
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: 929QK0RN XM Status: Active
OnStar Vehicle Diagnostics: Y DMN Enabled: Y
Bumper to Bumper Limited Warranty 09/01/2006 10 MI 09/01/2009 36,010 MI
Emission Select State Component Lty Wty 09/01/2006 10 MI 09/01/2013 70,010 MI
Powertrain Limited Warranty 09/01/2006 10 MI 09/01/2011 100,010 MI
Special Coverage 09239 09/01/2006 10 MI 09/01/2016 100,010 MI
Emission Limited Warranty 09/01/2006 10 MI 09/01/2009 50,010 MI
Corrosion Limited Warranty 09/01/2006 10 MI 09/01/2012 100,010 MI
Emission Select Component Ltd Wty 09/01/2006 10 MI 09/01/2014 80,010 MI
Service Contract
10/20/2012 Q27281 ZREG----Regular Vehicle Transaction Z8023 - ONSTAR - FUEL 122,667 MI
07/06/2011 210866 ZREG----Regular Vehicle Transaction F1003 - Rear Propeller Shaft Rear Universal Joint Replacement 94,192 MI
03/31/2011 208617 ZPTC----Part Transaction - Over the Counter E2320 - Front Wheel Bearing and Hub Replacement 89,187 MI
11/28/2010 D67168 ZREG----Regular Vehicle Transaction Z2083 - ROADSIDE SERVICE (BATTERY/JUMP START) 82,800 MI
11/22/2010 205907 ZREG----Regular Vehicle Transaction C0810 - Liftgate Window Replacement 82,898 MI
11/22/2010 205907 ZREG----Regular Vehicle Transaction T5752 - 09239 - Replace Front or Rear Door Handle Levers 82,898 MI
07/14/2010 202930 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 78,474 MI
07/14/2010 202930 ZREG----Regular Vehicle Transaction L2300 - Catalytic Converter Replacement 78,474 MI
03/28/2009 182196 ZREG----Regular Vehicle Transaction Z2080 - ROADSIDE SERVICE (TOWING) 52,000 MI
02/23/2009 192535 ZREG----Regular Vehicle Transaction C9021 - Buckle, Seatbelt (Front) (Left) - Replace 51,100 MI
02/23/2009 192535 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 51,100 MI
10/31/2007 182003 ZREG----Regular Vehicle Transaction R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 23,719 MI
10/31/2007 182003 ZREG----Regular Vehicle Transaction H0132 - Rear Brake Rotor Refinishing 23,719 MI
10/31/2007 182003 ZREG----Regular Vehicle Transaction R0760 - Radio Replacement 23,719 MI
10/31/2007 182003 ZREG----Regular Vehicle Transaction H0122 - Front Brake Rotor Refinishing 23,719 MI
10/31/2007 182003 ZREG----Regular Vehicle Transaction Z7902 - 2-DAY COURTESY TRANSPORTATION 23,719 MI
02/22/2007 175781 ZREG----Regular Vehicle Transaction N9995 - Customer Concern Not Duplicated - Electrical 9,358 MI
02/22/2007 175781 ZREG----Regular Vehicle Transaction Y0124 - 06162 Product Enhancement - Engine Control Module Reprogram with SPS 9,358 MI
02/22/2007 175781 ZREG----Regular Vehicle Transaction Y0151 - 07007- Service Update - Reprogram BCM, RCDLR, and RKE Transmitters 9,358 MI
02/22/2007 175781 ZREG----Regular Vehicle Transaction Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 9,358 MI
06/08/2006 A31680 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
mturnerua
Alabama
If Drew or anyone wouldn't mind I would like to have the service history and a Carfax for a 2009 Suburban I'm looking at. 1GNFK36349J107509 Thanks
riggz
North of Atlanta, GA
Ohh! Do mine too! :angels25: 1GNFK36339R210227
My dealer was able to pull up some service history but unable to print it out.
doubletapdrew
I can't do carfax (they charge us for them), here's GM veh history:
Vehicle Information
VIN: 1GNFK36349J107509 Model: CK10906-2009 SUBURBAN 4WD 1/2 TON
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: L31G12WM XM Status: Active
Corrosion Limited Warranty 03/16/2009 320 MI 03/16/2015 100,320 MI
Emission Select Component Ltd Wty 03/16/2009 320 MI 03/16/2017 80,320 MI
Bumper to Bumper Limited Warranty 03/16/2009 320 MI 03/16/2012 36,320 MI
Powertrain Limited Warranty 03/16/2009 320 MI 03/16/2014 100,320 MI
Special Coverage 11273 03/16/2009 320 MI 03/16/2019 120,320 MI
Service Contract
01/12/2010 234989 ZREG----Regular Vehicle Transaction N3240 - Rear Seat Recliner Actuator Replacement 31,015 MI
05/29/2009 224827 ZREG----Regular Vehicle Transaction R0862 - Head, Rear Compartment Audio Control - Replace 7,210 MI
09/24/2008 A07509 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 2 MI
09/18/2008 A07509 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
---------- Post added at 01:20 PM ---------- Previous post was at 01:19 PM ----------
VIN: 1GNFK36339R210227 Model: CK10906-2009 SUBURBAN 4WD 1/2 TON
Order Type: 60 - RETAIL - SOLD
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: ZDR832RA XM Status: Active
Corrosion Limited Warranty 04/09/2009 5 MI 04/09/2015 100,005 MI
Emission Select Component Ltd Wty 04/09/2009 5 MI 04/09/2017 80,005 MI
Bumper to Bumper Limited Warranty 04/09/2009 5 MI 04/09/2012 36,005 MI
Emission Select State Component Lty Wty 04/09/2009 5 MI 04/09/2016 70,005 MI
Powertrain Limited Warranty 04/09/2009 5 MI 04/09/2014 100,005 MI
Emission Limited Warranty 04/09/2009 5 MI 04/09/2012 50,005 MI
Special Coverage 11273 04/09/2009 5 MI 04/09/2019 120,005 MI
Service Contract
10/16/2013 143087 ZREG----Regular Vehicle Transaction 3010060 - Front Drive Axle Actuator Replacement 54,933 MI
09/23/2013 142178 ZREG----Regular Vehicle Transaction 1033270 - Instrument Panel Upper Trim Panel Replacement 54,394 MI
09/22/2012 33271 ZREG----Regular Vehicle Transaction J0981 - Valve Lifter Oil Filter Replacement 38,438 MI
06/06/2012 29583 ZREG----Regular Vehicle Transaction C6001 - Front Seat Adjuster Replacement 32,510 MI
06/06/2012 29583 ZREG----Regular Vehicle Transaction C6005 - Front Seat Adjuster Replacement 32,510 MI
06/06/2012 29583 ZREG----Regular Vehicle Transaction N0126 - Battery Negative Cable Replacement 32,510 MI
04/28/2012 28337 ZREG----Regular Vehicle Transaction D1443 - Instrument Panel Center Air Outlet Replacement - Left Side 30,521 MI
04/28/2012 28337 ZREG----Regular Vehicle Transaction N0110 - Battery - One - Replace 30,521 MI
03/28/2012 27355 ZREG----Regular Vehicle Transaction N1720 - Fuse - Replace 28,871 MI
10/26/2010 628275 ZREG----Regular Vehicle Transaction N2590 - Switch - Windshield Washer Fluid Level - Replace 14,174 MI
03/09/2009 A10227 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Ja1034
