service history from vin#?
doubletapdrew
Note to self: Contact Drew next time I needs teh vine. :)
Where you at doubletap?
I'm in Oregon. We are still waiting for the 2014 sierras we have on order to show up, but I guess they revealed the 6.2L is going to be around 420hp so I have to wait to see the new Yukon Denalis :driver:
08grey
i know my tranny was replaced at about 20k but dont have any idea why, drew do you think they record that information?
doubletapdrew
If it was done at a GM dealer and under warranty they should. If you PM me your VIN i can look it up.
It probably won't say WHY though. Just that it was replaced.
Could be any number of things. In the 80's GM decided it was cheaper to replace whole components (engines, transmissions, etc) than the time and labor to tear them apart and fix what was wrong. The dealer sends back the core and GM rebuilds it and sells it as a reman.
soulsea
Bar
Usually the report reads worse than it really is, plus dealers sometimes will fiddle with the VIN ... I know my guys at the body shop will often grab another VIN when they do painting or demolding from me when they put it in the books so that it doesn't show up on my vehicle's VIN service history. Not often mind you, but it does happen. :emotions33:
It also happened when I traded my 11 Esky for the 12 and the dealer forgot to put in the new number ... found out a couple of days ago that all the LED headlamp swap work on the 12 has been going on the 11 VIN that I don't own any more. Which is fine by me but probably confusing to the new owner of the 11 if he/she ever sees the report.
The most infuriating thing to see in the report is the dreaded CCND ... then you don't know what the hell's going on.
soulsea
Bar
Customer Concern Not Duplicated
You take it in and tell them the issue, they can't replicate it when they go to work on the truck, so they hand you back the key without fixing anything.
dgrammer
I know this is an old post but could anyone possibly run vin 1gchk23182f192037 for service history? Buying this tomorrow and have the autocheck but it didn't really tell me anything and dealers were already closed today. Thank you in advance if so.
doubletapdrew
Here's what GM has:
Vehicle Information
VIN: 1GCHK23182F192037 Model: CK25743-2002 SILVERADO 2500HD 4WD CREW
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N050546 05546 15,000 MILE - 24,000 KM FUEL FILTER CHANGE **IN EFFECT UNTIL SEPT. 30, 2006** 08/10/2005 Closed
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: N XM Radio ID: XM Status: NA
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Limited Warranty 03/22/2002 398 MI 03/22/2007 100,398 MI
Bumper to Bumper Limited Warranty 03/22/2002 398 MI 03/22/2005 36,398 MI
Special Coverage 04039 03/22/2002 398 MI 03/22/2009 200,398 MI
Diesel Engine Ltd Wty with Deductible 03/22/2002 398 MI 03/22/2007 100,398 MI
Corrosion Limited Warranty 03/22/2002 398 MI 03/22/2008 100,398 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
06/25/2009 153423 ZREG----Regular Vehicle Transaction Z2175 - $15 Maintenance Card Promotion 161,016 MI
08/26/2005 329909 ZFAT----Field Action Recall V1242 - 04007 - Inspect and Replace Tailgate Support Cables inc. Hinge Replacement if Necessary 95,370 MI
08/26/2005 329909 ZFAT----Field Action Recall V1380 - 05546 - Replace Fuel Filter 95,370 MI
05/13/2003 098532 ZREG----Regular Vehicle Transaction D1002 - Blower Motor Resistor Replacement 35,063 MI
05/13/2003 098532 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 35,063 MI
05/08/2003 098415 ZREG----Regular Vehicle Transaction N6600 - Brake System/Traction Control Wiring and/or Connector Repair or Replacement 33,848 MI
02/22/2002 A92037 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Looks like there were 2 field actions (recalls) but they've both been done.
davidl13
Hello,
I am about to purchase a 2012 yukon xl denali.
I would really appreciate any help i can get in finding out the service history on this vehicle.
It has 20k miles and has had 2 owners. Began life as a hertz fleet vehicle until 14k and then a private owner for 6 k.
Can you help me see the service info
Vin #. 1GKS2MEF1CR196459
David
Service departments and some other GM employees have access to the full warranty/service history of a vehicle, as long as it was performed at a GM dealership.It's not that difficult to get if you ask nicely cause there are always folks on GM forums that have access to the records, although it's usually better to ask before purchasing the vehicle rather than after. :)
bobarich
