service history from vin#?
doubletapdrew
Pretty please Drew , can you take a look at 1GNEK13027R170519
Thank you :secret:
Vehicle Information
VIN: 1GNEK13027R170519 Model: CK10706-2007 TAHOE 4WD LT
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 50 - FLEET
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Service Update Bulletins N070033 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* 02/06/2007 Closed
Service Update Bulletins N060162 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 12/12/2006 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Bumper to Bumper Limited Warranty 04/11/2006 7 MI 04/11/2009 36,007 MI
Corrosion Limited Warranty 04/11/2006 7 MI 04/11/2012 100,007 MI
Emission Select Component Ltd Wty 04/11/2006 7 MI 04/11/2014 80,007 MI
Powertrain Limited Warranty 04/11/2006 7 MI 04/11/2011 100,007 MI
Special Coverage 09239 04/11/2006 7 MI 04/11/2016 100,007 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
06/14/2013 06553 ZFAT----Field Action Recall Y0152 - 07033 - Service Update - Reprogram BCM 86,270 MI
04/22/2011 335818 ZREG----Regular Vehicle Transaction J5490 - Throttle Body Assembly Replacement 79,924 MI
01/08/2010 306773 ZREG----Regular Vehicle Transaction Y0124 - 06162 Product Enhancement - Engine Control Module Reprogram with SPS 62,694 MI
01/08/2010 306773 ZREG----Regular Vehicle Transaction F2383 - Drive Pinion and Ring Gear Replacement 62,694 MI
04/16/2008 272218 ZREG----Regular Vehicle Transaction J6400 - Evaporative Emission Canister Purge Solenoid Valve Replacement 34,212 MI
12/13/2007 265106 ZREG----Regular Vehicle Transaction D4707 - HVAC System Control Module Reprogramming with SPS 28,032 MI
12/13/2007 265106 ZREG----Regular Vehicle Transaction J6354 - Powertrain Control Module Engine Reprogramming with SPS 28,032 MI
12/11/2007 R74302 ZREG----Regular Vehicle Transaction Z2080 - ROADSIDE SERVICE (TOWING) 27,000 MI
12/11/2007 264963 ZREG----Regular Vehicle Transaction J5490 - Throttle Body Assembly Replacement 27,970 MI
11/08/2007 263080 ZREG----Regular Vehicle Transaction J6441 - Evaporative Emission Canister Vent Solenoid Valve Replacement 21,044 MI
11/08/2007 263080 ZREG----Regular Vehicle Transaction L0620 - Evaporative Emission Canister Replacement 21,044 MI
11/08/2007 263080 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 21,044 MI
07/13/2007 255692 ZREG----Regular Vehicle Transaction N2411 - Front Seat Adjuster Switch Replacement - Driver Side 15,637 MI
05/31/2007 252634 ZREG----Regular Vehicle Transaction Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 9,318 MI
04/18/2007 250183 ZREG----Regular Vehicle Transaction B7289 - Headlamp/Composite Assembly - Left - Replace 9,318 MI
04/18/2007 250183 ZREG----Regular Vehicle Transaction E5807 - Rear Shock Absorber Replacement - Both Sides 9,318 MI
04/18/2007 250183 ZREG----Regular Vehicle Transaction N6600 - Brake System/Traction Control Wiring and/or Connector Repair or Replacement 9,318 MI
---------- Post added at 12:37 PM ---------- Previous post was at 12:36 PM ----------
Could you help me out with VIN: 3GYFK62837G251895
Vehicle Information
VIN: 3GYFK62837G251895 Model: 6K10936-2007 ESCALADE EXT UUV AWD
Order Type: 70 - RETAIL - STOCK
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Branded Title
Warranty Block
Service Information
Type Number Description Posted Date
SB SB10168 Free Agent Best Practices for HUMMER, Pontiac, Saab and Saturn Customers or Those Affected by Dealership Consolidation 07/20/2010
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: 5VK9Q0HC XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Emission Select State Component Lty Wty 09/11/2007 6 MI 09/11/2014 70,006 MI
Emission Limited Warranty 09/11/2007 6 MI 09/11/2010 50,006 MI
Powertrain Limited Warranty 09/11/2007 6 MI 09/11/2012 100,006 MI
Bumper to Bumper Limited Warranty 09/11/2007 6 MI 09/11/2011 50,006 MI
Emission Select Component Ltd Wty 09/11/2007 6 MI 09/11/2015 80,006 MI
Corrosion Limited Warranty 09/11/2007 6 MI 09/11/2013 Unlimited
Service Contract
01/02/2012 224253 ZREG----Regular Vehicle Transaction J1501 - Engine Front Mount Replacement - Left Side 79,039 MI
08/17/2010 208040 ZREG----Regular Vehicle Transaction N0110 - Battery Replacement 49,861 MI
08/17/2010 208040 ZREG----Regular Vehicle Transaction N9993 - Customer Concerned Not Duplicated (CCND) - Electronics/Safety/Seat/Lighting/Keyless Entry/Theft Alarm 49,861 MI
08/17/2010 208040 ZREG----Regular Vehicle Transaction E3350 - Cross Member, Torsion Bar Support - Replace 49,861 MI
08/17/2010 208040 ZREG----Regular Vehicle Transaction B2900 - Sunroof Sunshade Replacement 49,861 MI
08/17/2010 208040 ZREG----Regular Vehicle Transaction B4280 - Front Side Door Inside Handle Replacement 49,861 MI
08/17/2010 208040 ZREG----Regular Vehicle Transaction B4521 - Rear Side Door Outside Handle Replacement - Left Side 49,861 MI
08/17/2010 208040 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 49,861 MI
03/24/2009 192760 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 26,125 MI
03/24/2009 192760 ZREG----Regular Vehicle Transaction C1282 - Cargo Box Stowage and Midgate Window Opening Weatherstrip Replacement 26,125 MI
03/24/2009 192760 ZREG----Regular Vehicle Transaction C0183 - Front Side Door Window Regulator Replacement - Left Side 26,125 MI
03/24/2009 192760 ZREG----Regular Vehicle Transaction C0182 - Front Side Door Window Regulator Replacement 26,125 MI
03/24/2009 192760 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 26,125 MI
03/24/2009 192760 ZREG----Regular Vehicle Transaction N0100 - Battery Charging and Testing 26,125 MI
11/17/2008 189161 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 18,304 MI
11/17/2008 189161 ZREG----Regular Vehicle Transaction B4010 - Front Side Door Upper Hinge and Lower Hinge Replacement 18,304 MI
10/20/2008 188260 ZREG----Regular Vehicle Transaction B4121 - Front Side Door Outside Handle Replacement - Left Side 17,170 MI
10/20/2008 188260 ZREG----Regular Vehicle Transaction B4520 - Rear Side Door Outside Handle Replacement - Right Side 17,170 MI
10/20/2008 188260 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 17,170 MI
06/09/2008 238189 ZREG----Regular Vehicle Transaction N2131 - Door Lock and Side Window Switch Replacement - Driver Side 11,891 MI
06/09/2008 238189 ZREG----Regular Vehicle Transaction B1670 - Hood Strut Replacement 11,891 MI
06/09/2008 238189 ZREG----Regular Vehicle Transaction N0850 - Front Fog Lamp Bulb Replacement 11,891 MI
06/09/2008 238189 ZREG----Regular Vehicle Transaction E7690 - Sensor, Steering Wheel Rotation - Replace 11,891 MI
06/09/2008 238189 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 11,891 MI
05/13/2008 034972 ZREG----Regular Vehicle Transaction C8800 - Inflatable Restraint Steering Wheel Module Coil Replacement 11,473 MI
05/13/2008 034972 ZREG----Regular Vehicle Transaction E0716 - Diagnostic System Check - Tire Pressure Monitoring 11,473 MI
05/13/2008 034972 ZREG----Regular Vehicle Transaction E1104 - Cushion Upper And/Or Shim, Body (Left) - R&R Or Replace 11,473 MI
05/13/2008 034972 ZREG----Regular Vehicle Transaction Z7904 - 4-DAY COURTESY TRANSPORTATION 11,473 MI
10/18/2007 031018 ZREG----Regular Vehicle Transaction E9740 - Steering Gear Replacement 2,115 MI
10/18/2007 031018 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 2,115 MI
10/18/2007 031018 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 2,115 MI
03/01/2007 026103 ZREG----Regular Vehicle Transaction Y0152 - 07033 - Service Update - Reprogram BCM 6 MI
12/06/2006 A51895 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
The Black Fleet
Hey Drew,
I know you are running a lot numbers but, could you do mine to, already purchased the vehicle but still like to know.
Vin 1GNEK13Z23R106344
Thanks in advance........
doubletapdrew
Hey Drew,
Looks like there is still an open recall on it for 2nd row center seatbelt
Vehicle Information
VIN: 1GNEK13Z23R106344 Model: CK15706-2003 TAHOE 1/2 TON 4WD
Field Actions: 1 Open
Product Safety Recall N050037 05037 SECOND ROW CENTER SAFETY BELT 07/14/2005 Open
Branded Title
Warranty Block
Service Information
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: CP1N00WN XM Status: Inactive
Special Coverage-07187 09/24/2002 45 MI 09/24/2009 80,045 MI
Corrosion Limited Warranty 09/24/2002 45 MI 09/24/2008 100,045 MI
Bumper to Bumper Limited Warranty 09/24/2002 45 MI 09/24/2005 36,045 MI
Emission Select Component Ltd Wty 09/24/2002 45 MI 09/24/2010 80,045 MI
Service Contract
08/15/2005 170060 ZREG----Regular Vehicle Transaction E7700 - Intermediate Steering Shaft Replacement 22,285 MI
04/07/2005 164941 ZREG----Regular Vehicle Transaction C7420 - Lock, Folding Second Seat Cushion - R&R Or Replace 21,905 MI
04/13/2004 150867 ZREG----Regular Vehicle Transaction N5510 - Driver or Passenger Seat Adjuster Memory Module Replacement 20,321 MI
12/23/2003 109139 ZREG----Regular Vehicle Transaction N1780 - Circuit Breaker - Replace 18,478 MI
06/19/2003 101497 ZREG----Regular Vehicle Transaction E7012 - Switch And/Or Control, Steering Wheel Mounted - Replace 11,425 MI
06/11/2003 101157 ZREG----Regular Vehicle Transaction R9230 - Audio/XM Radio Package Replacement 11,244 MI
06/11/2003 101157 ZREG----Regular Vehicle Transaction K4122 - Transfer Case Shift Control Module Replacement 11,244 MI
05/19/2003 100179 ZREG----Regular Vehicle Transaction C6041 - Adjuster Assembly, Front Seat Power - Bucket Seat - Driver - R&R Or Replace 10,512 MI
02/21/2003 010813 ZREG----Regular Vehicle Transaction B5700 - Liftgate Assembly - Align 7,031 MI
12/09/2002 093808 ZREG----Regular Vehicle Transaction C7171 - Heating Element, Left Front Seat - Replace 4,082 MI
08/02/2002 A06344 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
For this vehicle:
→ View Vehicle Summary
→ Service Contract
→ Branded Title
→ Warranty Block
→ View Vehicle Build
→ View Vehicle Component Summary
→ View Vehicle Transaction History Detail
→ View Vehicle Delivery Information
→ Investigate Major Assembly History
thallen160
Vin
Thanks for the info. Could you help with one more VIN?
1GNSCBE06DR343442
booyaltz
I am looking to buy a 2007 Cadillac Escalade esv with vin 1GYFK668X7R366567. Can someone look up the carfax/service history? Thanks!!
doubletapdrew
Thank you so much Drew ! :cheers:
The only thing that got me puzzled is that this Tahoe is LS version and not LT :jawdrop:
It says it's a LT...
---------- Post added at 11:39 AM ---------- Previous post was at 11:37 AM ----------
1GNSCBE06DR343442
Vehicle Information
VIN: 1GNSCBE06DR343442 Model: CC10706-2013 TAHOE 1500 2WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: QKBQQ28X XM Status: Active
Powertrain Limited Warranty 05/21/2013 9 MI 05/21/2018 100,009 MI
Emission Select Component Ltd Wty 05/21/2013 9 MI 05/21/2021 80,009 MI
Bumper to Bumper Limited Warranty 05/21/2013 9 MI 05/21/2016 36,009 MI
Corrosion Limited Warranty 05/21/2013 9 MI 05/21/2019 100,009 MI
Service Contract
05/22/2013 A43442 ZPDI----Pre-Delivery Inspection 0590072 - Pre-Delivery Inspection - Base Time 1 MI
---------- Post added at 11:42 AM ---------- Previous post was at 11:39 AM ----------
I can't do carfax but here's the GM service history
Vehicle Information
VIN: 1GYFK668X7R366567 Model: 6K10906-2007 ESCALADE ESV SUV AWD
Service Contract: No Branded Title: Yes Warranty Block: Yes PDI Status: No
Branded Title
Brand Description: SALVAGED Date Branded: 11/01/2013
Title Number: Reporting Source Code:
Reported By: MD Effective Date: 11/29/2013
Warranty Block
Code Description Effective Date
BT BRANDED TITLE 11/29/2013
Block Transaction Types:
ZPDI
ZPTI
ZREG
ZSCT
Blocked Labour Ops:
Service Information
XM Equipped: Y XM Radio ID: 598UT043 XM Status: Active
Bumper to Bumper Limited Warranty 04/21/2007 49 MI 04/21/2011 50,049 MI
Corrosion Limited Warranty 04/21/2007 49 MI 04/21/2013 Unlimited
Emission Select Component Ltd Wty 04/21/2007 49 MI 04/21/2015 80,049 MI
Powertrain Limited Warranty 04/21/2007 49 MI 04/21/2012 100,049 MI
Service Contract
08/19/2010 6016519 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 49,523 MI
08/19/2010 6016519 ZREG----Regular Vehicle Transaction B4521 - Rear Side Door Outside Handle Replacement - Left Side 49,523 MI
11/11/2009 6007264 ZREG----Regular Vehicle Transaction N1720 - Fuse Replacement 48,238 MI
03/09/2009 561566 ZREG----Regular Vehicle Transaction C6068 - Driver or Passenger Seat Back Cushion Frame Replacement 38,841 MI
03/09/2009 561566 ZREG----Regular Vehicle Transaction E0032 - Cap, Wheel Center - Front - Replace 38,841 MI
03/09/2009 561566 ZREG----Regular Vehicle Transaction B4120 - Front Side Door Outside Handle Replacement - Right Side 38,841 MI
12/12/2008 244299 ZREG----Regular Vehicle Transaction Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 33,774 MI
12/06/2008 Z55220 ZREG----Regular Vehicle Transaction Z2085 - ROADSIDE SERVICE (PREMIUM) 33,000 MI
12/04/2008 558230 ZREG----Regular Vehicle Transaction E0100 - Pull and Torque Steer Analysis 33,623 MI
12/04/2008 558230 ZREG----Regular Vehicle Transaction E0716 - Diagnostic System Check - Tire Pressure Monitoring 33,623 MI
12/04/2008 558230 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 33,623 MI
03/06/2008 268586 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 17,460 MI
03/06/2008 268586 ZREG----Regular Vehicle Transaction N6606 - Fuel System Wiring and/or Connector Repair or Replacement 17,460 MI
02/08/2008 267598 ZREG----Regular Vehicle Transaction R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 16,615 MI
02/08/2008 267598 ZREG----Regular Vehicle Transaction R0760 - Radio Replacement 16,615 MI
01/03/2008 266289 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 15,682 MI
01/03/2008 266289 ZREG----Regular Vehicle Transaction N9995 - Customer Concern Not Duplicated - Electrical 15,682 MI
12/20/2007 265925 ZREG----Regular Vehicle Transaction C3540 - Rear Side Door Trim Panel Replacement - Right Side 15,243 MI
12/20/2007 265925 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 15,243 MI
10/30/2007 264221 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 12,631 MI
10/30/2007 264221 ZREG----Regular Vehicle Transaction C2990 - Knob, Control And/Or Select - One And/Or All - Replace 12,631 MI
10/30/2007 264221 ZREG----Regular Vehicle Transaction D9708 - Install Foam on Center Air Deflector 12,631 MI
08/16/2007 261424 ZREG----Regular Vehicle Transaction B4001 - Front Side Door Adjustment - Left Side 7,823 MI
08/16/2007 261424 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 7,823 MI
05/09/2007 257802 ZREG----Regular Vehicle Transaction N4210 - Display Clock Replacement 1,061 MI
05/09/2007 257802 ZREG----Regular Vehicle Transaction B7846 - Front Side Door Window Reveal Molding Replacement 1,061 MI
05/09/2007 257802 ZREG----Regular Vehicle Transaction C2362 - Instrument Panel Upper Trim Panel Replacement 1,061 MI
05/09/2007 257802 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 1,061 MI
04/26/2007 257375 ZREG----Regular Vehicle Transaction B7926 - Rear Side Door Window Reveal Molding Replacement 303 MI
03/06/2007 A66567 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
lordflash
