service history from vin#?
Texfan00
Hi Drew,
I just bought the vehicle a few months ago and wanted to get some information on it. When you a minute could you please run my VIN#1GNFC13017R175020, I appreciate your time and help.
Thank You
doubletapdrew
Hi Drew,
Thank You
Looks like the heated windshield washer recall is still open on it. So be aware if you take it into a dealer they'll probably do it automatically unless you tell them you want to keep it (they'll probably have you sign a wavier releasing GM from any liability if it burns down the vehicle, although I don't really think that's a big concern on them, I would have liked to keep it but mine's an 11 so it didn't have the module or switch by then). In my 07 I had them replace the unit with an alphatherm replacement module when they yanked the factory one out. If you go that route I think GM is supposed to send you a check for $100 for the "inconvenience", which will cover the cost of the alphatherm unit.
Vehicle Information
VIN: 1GNFC13017R175020 Model: CC10706-2007 TAHOE 4X2 LT
Service Contract: Yes Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 1 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Service Update Bulletins N060162 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 12/12/2006 Closed
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Open
Service Update Bulletins N070033 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* 02/06/2007 Closed
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: 4VE8H00M XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Special Coverage 09239 06/01/2006 12 MI 06/01/2016 100,012 MI
Bumper to Bumper Limited Warranty 06/01/2006 12 MI 06/01/2009 36,012 MI
Powertrain Limited Warranty 06/01/2006 12 MI 06/01/2011 100,012 MI
Corrosion Limited Warranty 06/01/2006 12 MI 06/01/2012 100,012 MI
Emission Select Component Ltd Wty 06/01/2006 12 MI 06/01/2014 80,012 MI
Service Contract
Policy Number: 817282972 Owner: COBB
Description: GMPP 48/60 MAJOR GUARD Deductible Amount: 200.00
Effective Date: 02/20/2008 Expiration Date: 02/20/2012
Effective Odometer: 28505 MI Expiration Odometer: 88505 MI
Daily Rental Limit: 35.00
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
10/27/2008 W14786 ZREG----Regular Vehicle Transaction Y0124 - 06162 Product Enhancement - Engine Control Module Reprogram with SPS 35,775 MI
10/27/2008 W14786 ZREG----Regular Vehicle Transaction Y0152 - 07033 - Service Update - Reprogram BCM 35,775 MI
10/27/2008 W14786 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 35,775 MI
10/27/2008 W14786 ZREG----Regular Vehicle Transaction R4490 - Remote Control Door Lock Transmitter Replacement 35,775 MI
03/31/2008 U42383 ZREG----Regular Vehicle Transaction Z2084 - ROADSIDE SERVICE (FLAT TIRE) 30,218 MI
10/17/2006 H10150 ZREG----Regular Vehicle Transaction Z2083 - ROADSIDE SERVICE (BATTERY/JUMP START) 7,000 MI
04/18/2006 A75020 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
08Suburban
Drew, I'm new to the forum and going to look at and seriously considering buying an 08 Suburban, Can you run the VIN for me. I really appreciate it. It has high mileage and I want to see if/what has been replaced if the dealer did any of the work.
VIN 1GNFK16318R106273
Thanks
doubletapdrew
Thanks
Looks like it just had one warranty claim recorded
Vehicle Information
VIN: 1GNFK16318R106273 Model: CK10906-2008 SUBURBAN 4WD 1/2 TON
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Field Actions: 0 Open
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: ZVDKV0HY XM Status: Active
Emission Limited Warranty 11/30/2007 74 MI 11/30/2010 50,074 MI
Special Coverage 11273 11/30/2007 74 MI 11/30/2017 120,074 MI
Corrosion Limited Warranty 11/30/2007 74 MI 11/30/2013 100,074 MI
Powertrain Limited Warranty 11/30/2007 74 MI 11/30/2012 100,074 MI
Emission Select Component Ltd Wty 11/30/2007 74 MI 11/30/2015 80,074 MI
Bumper to Bumper Limited Warranty 11/30/2007 74 MI 11/30/2010 36,074 MI
Emission Select State Component Lty Wty 11/30/2007 74 MI 11/30/2014 70,074 MI
Service Contract
Vehicle has no current record of service contracts.
09/09/2008 977139 ZREG----Regular Vehicle Transaction N9562 - Inspection and repair of B-pillar wiring 23,010 MI
07/18/2007 A06273 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
08Suburban
looks like it just had one warranty claim recorded
vehicle information
vin: 1gnfk16318r106273 model: Ck10906-2008 suburban 4wd 1/2 ton
service contract: No branded title: No warranty block: No pdi status: No
order type: 70 - retail - stock
field actions: 0 open
required field actions open field actions are highlighted
vehicle has no current record of required field actions.
Branded title
*the vin information contained herein and information derived therefrom is the proprietary property of the polk company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Warranty block
vehicle has no current record of warranty block.
Service information
vehicle has no current record of outstanding service information.
Onstar and xm satellite radio information
refer to help page for details. For onstar contact 888.on.star1 (888.667.8271) and for xm radio contact 877.get.xmst (877.438.9677 canada) and in the usa:800-556-3600.
Onstar equipped: Y onstar status: Inactive
xm equipped: Y xm radio id: Zvdkv0hy xm status: Active
onstar vehicle diagnostics: N dmn enabled: N
applicable warranties valid warranties are highlighted
valid description start date effective odometer end date end odometer
emission limited warranty 11/30/2007 74 mi 11/30/2010 50,074 mi
special coverage 11273 11/30/2007 74 mi 11/30/2017 120,074 mi
corrosion limited warranty 11/30/2007 74 mi 11/30/2013 100,074 mi
powertrain limited warranty 11/30/2007 74 mi 11/30/2012 100,074 mi
emission select component ltd wty 11/30/2007 74 mi 11/30/2015 80,074 mi
bumper to bumper limited warranty 11/30/2007 74 mi 11/30/2010 36,074 mi
emission select state component lty wty 11/30/2007 74 mi 11/30/2014 70,074 mi
service contract
vehicle has no current record of service contracts.
Transaction history view details
job card date job card number transaction type transaction adjustment labour operation odometer reading
09/09/2008 977139 zreg----regular vehicle transaction n9562 - inspection and repair of b-pillar wiring 23,010 mi
07/18/2007 a06273 zpdi----pre-delivery inspection z7000 - pre-delivery inspection - base time 0 mi
thanks!!
doubletapdrew
Vehicle Information
VIN: 1GKFK06239R290616 Model: TK10906-2009 YUKON XL 1/2 TON - 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: C9TU22WQ XM Status: Active
Bumper to Bumper Limited Warranty 11/18/2009 226 MI 11/18/2012 36,226 MI
Emission Select Component Ltd Wty 11/18/2009 226 MI 11/18/2017 80,226 MI
Corrosion Limited Warranty 11/18/2009 226 MI 11/18/2015 100,226 MI
Powertrain Limited Warranty 11/18/2009 226 MI 11/18/2014 100,226 MI
Service Contract
04/05/2011 119092 ZREG----Regular Vehicle Transaction J5490 - Throttle Body Assembly Replacement 27,997 MI
09/28/2009 345574 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 1 MI
09/25/2009 A90616 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
For this vehicle:
→ View Vehicle Summary
→ Service Contract
→ Branded Title
→ Warranty Block
→ View Vehicle Build
→ View Vehicle Component Summary
→ View Vehicle Transaction History Detail
→ View Vehicle Delivery Information
browner010
