service history from vin#?
GOHAWKS
Hi Drew,
When you a minute could you please run my VIN#1GNFK13077J142251, I appreciate your time and help.
Thank You
doubletapdrew
Hi Drew,
Thank You
Vehicle Information
VIN: 1GNFK13077J142251 Model: CK10706-2007 TAHOE 4WD LT
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 60 - RETAIL - SOLD
Field Actions: 1 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Service Update Bulletins N060162 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 12/12/2006 Closed
Service Update Bulletins N070033 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* 02/06/2007 Open
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: U82UH00Q XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Powertrain Limited Warranty 04/26/2006 10 MI 04/26/2011 100,010 MI
Special Coverage 09239 04/26/2006 10 MI 04/26/2016 100,010 MI
Corrosion Limited Warranty 04/26/2006 10 MI 04/26/2012 100,010 MI
Emission Select Component Ltd Wty 04/26/2006 10 MI 04/26/2014 80,010 MI
Bumper to Bumper Limited Warranty 04/26/2006 10 MI 04/26/2009 36,010 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
01/18/2011 553642 ZREG----Regular Vehicle Transaction T5753 - 09239 - Replace Front and Rear Door Handle Levers 63,143 MI
11/02/2010 548835 ZREG----Regular Vehicle Transaction J3480 - Pump And/Or Gasket, Coolant - Replace 60,337 MI
05/26/2009 517209 ZREG----Regular Vehicle Transaction F1440 - Output Shaft Seal Replacement - Right Side 40,351 MI
04/06/2009 514381 ZREG----Regular Vehicle Transaction Y0124 - 06162 Product Enhancement - Engine Control Module Reprogram with SPS 38,468 MI
03/26/2008 493508 ZREG----Regular Vehicle Transaction E0722 - Tire Pressure Indicator Sensor Replacement 26,219 MI
03/26/2008 493508 ZREG----Regular Vehicle Transaction D1812 - Temperature Valve Actuator Replacement - Left Side 26,219 MI
04/19/2006 450023 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 5 MI
04/03/2006 A42251 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
jokeracing
Hi Drew,
Wondering if you could run my Vin 1GNSKBE05DR131389.
Bought it from a local dealer a few months ago. Ran a carfax but didn't get much info out of it.
Thanks for your time and help
Sent from my SM-N900W8 using Tapatalk
doubletapdrew
Hi Drew,
Not much info here either
Vehicle Information
VIN: 1GNSKBE05DR131389 Model: CK10706-2013 TAHOE 1500 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 50 - FLEET
Field Actions: 0 Open
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: V7GHM2C9 XM Status: Active
OnStar Vehicle Diagnostics: Y DMN Enabled: Y
Powertrain Limited Warranty 07/11/2012 9 MI 07/11/2017 100,009 MI
Emission Select Component Ltd Wty 07/11/2012 9 MI 07/11/2020 80,009 MI
Emission Limited Warranty 07/11/2012 9 MI 07/11/2015 50,009 MI
Corrosion Limited Warranty 07/11/2012 9 MI 07/11/2018 100,009 MI
Bumper to Bumper Limited Warranty 07/11/2012 9 MI 07/11/2015 36,009 MI
Emission Select State Component Lty Wty 07/11/2012 9 MI 07/11/2019 70,009 MI
Service Contract
07/11/2012 A31389 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
jokeracing
Vehicle Information
Branded Title
Warranty Block
Service Information
Service Contract
Thanks for the look up.
I just purchased this truck with 25000 kms on it. Is it normal for there to be nothing on there?
doubletapdrew
Yes if it's been reliable and they haven't had any problems they needed warranty on.
doubletapdrew
1GKFK13037J145225
Can you look up mine when you get a chance
Vehicle Information
VIN: 1GKFK13037J145225 Model: TK10706-2007 YUKON 1500 4WD
Order Type: 70 - RETAIL - STOCK
Service Update Bulletins N070033 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* 02/06/2007 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: LJ20J0WZ XM Status: Inactive
Emission Select Component Ltd Wty 02/23/2007 252 MI 02/23/2015 80,252 MI
Powertrain Limited Warranty 02/23/2007 252 MI 02/23/2012 100,252 MI
Special Coverage 09239 02/23/2007 252 MI 02/23/2017 100,252 MI
Bumper to Bumper Limited Warranty 02/23/2007 252 MI 02/23/2010 36,252 MI
Corrosion Limited Warranty 02/23/2007 252 MI 02/23/2013 100,252 MI
Service Contract
08/24/2010 259043 ZREG----Regular Vehicle Transaction T5752 - 09239 - Replace Front or Rear Door Handle Levers 70,431 MI
06/20/2008 197757 ZREG----Regular Vehicle Transaction C0183 - Front Side Door Window Regulator Replacement - Left Side 25,154 MI
06/20/2008 197757 ZREG----Regular Vehicle Transaction Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 25,154 MI
01/30/2008 193507 ZREG----Regular Vehicle Transaction C0331 - Strip, Rear Door Window Outer Sealing - Left - R&R Or Replace 18,550 MI
11/26/2007 191608 ZREG----Regular Vehicle Transaction Y0152 - 07033 - Service Update - Reprogram BCM 15,299 MI
11/26/2007 191608 ZREG----Regular Vehicle Transaction C0330 - Strip, Rear Door Window Outer Sealing - Right - R&R Or Replace 15,299 MI
11/26/2007 191608 ZREG----Regular Vehicle Transaction B7876 - Molding, Front Door - Left - Side - R&R Or Replace 15,299 MI
11/26/2007 191608 ZREG----Regular Vehicle Transaction Y0124 - 06162 Product Enhancement - Engine Control Module Reprogram with SPS 15,299 MI
04/06/2006 A45225 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
08grey
Fleet usually means rental car or limo when it comes to these trucks.
Jhawk79
