service history from vin#?
CrashTestDummy
Pearland, Texas
I'm sure most of the PDs have their own motor pool, so all it's showing is the trans dipstick tube recall:
Vehicle Information
VIN: 1GNMCAE02AR170890 Model: CC10706-2010 TAHOE 1500 2WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 50 - FLEET
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N120138 12138 TRANSMISSION DIPSTICK TUBE FRACTURE 10/24/2012 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Corrosion Limited Warranty 03/02/2010 11 MI 03/02/2016 100,011 MI
Emission Select Component Ltd Wty 03/02/2010 11 MI 03/02/2018 80,011 MI
Bumper to Bumper Limited Warranty 03/02/2010 11 MI 03/02/2013 36,011 MI
Powertrain Limited Warranty 03/02/2010 11 MI 03/02/2015 100,011 MI
Special Coverage 11273 03/02/2010 11 MI 03/02/2020 120,011 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
04/18/2013 756296 ZFAT----Field Action Recall V2645 - 12138 - Replace Transmission Filler Tube 70,373 MI
02/04/2010 A70890 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
---------- Post added at 10:21 AM ---------- Previous post was at 10:20 AM ----------
<SNIP>
That's cool. You're probably right, especially with some of the larger PDs, which I believe this one is. At least I know there are no outstanding recalls, or anything, and there's some warranty left. That's good news.
Thank you, again, you ROCK!!! :rockit:
firemedicmeyer
Any chance you could run the service history on my 2007 Suburban? The Vin is: 1GNFK16307J162282
I am replacing the engine and found 1 bolt that was different looking in the bellhousing and another that was missing. So naturally I am curious now. Thanks in advance!!
Hey Doubletap, can you check mine for me please? I just purchased my 05 Yukon less than 30 days ago. It came with no carfax report however when I punch in the vin, carfax shows 38 history reports. I just cant afford the $40 that they charge.
3GKFK16Z45G154685
Thanks!!
doubletapdrew
Vehicle Information
VIN: 3GKFK16Z45G154685 Model: TK15906-2005 GMC YUKON XL 1500 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 81 - DEALER USED CAR (CVMS USE)
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: XBZH7004 XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Corrosion Limited Warranty 03/11/2005 0 MI 03/11/2011 100,000 MI
Special Coverage-07187 03/11/2005 0 MI 03/11/2012 80,000 MI
Emission Select Component Ltd Wty 03/11/2005 0 MI 03/11/2013 80,000 MI
Bumper to Bumper Limited Warranty 03/11/2005 0 MI 03/11/2008 36,000 MI
Service Contract
06/05/2007 050879 ZREG----Regular Vehicle Transaction J9995 - Customer Concern Not Duplicated (CCND) - Emissions 16,756 MI
03/22/2007 048271 ZREG----Regular Vehicle Transaction L1020 - Fuel Tank Filler Cap Replacement 14,164 MI
12/19/2006 044912 ZREG----Regular Vehicle Transaction E9446 - I - Shaft Exercise/Stroke 12,267 MI
10/12/2006 042719 ZREG----Regular Vehicle Transaction E0600 - Hold-Down, Spare Tire - R&R Or Replace 10,500 MI
04/28/2005 027397 ZREG----Regular Vehicle Transaction B9654 - Lamp Assembly, Exterior - License (One Or Both) - Replace 11 MI
01/17/2005 093230 ZTPT----Transportation Transactions A0890 - Roof Panel Partial Refinish Color/Clear Coat 10 MI
12/22/2004 870426 ZTPT----Transportation Transactions T2020 - Towing 4 MI
12/22/2004 870426 ZTPT----Transportation Transactions A0880 - Roof Panel Partial Color/Clear Coat 4 MI
12/22/2004 870426 ZTPT----Transportation Transactions B1308 - Grille Assembly - One Piece - Replace 4 MI
12/22/2004 870426 ZTPT----Transportation Transactions B0800 - Rear Bumper Impact Bar Replacement 4 MI
10/21/2004 A54685 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
---------- Post added at 10:21 AM ---------- Previous post was at 10:16 AM ----------
Vehicle Information
VIN: 1GNFK16307J162282 Model: CK10906-2007 SUBURBAN 4WD 1/2 TON
Order Type: 70 - RETAIL - STOCK
Field Actions: 2 Open
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Service Update Bulletins N070033 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* 02/06/2007 Open
Service Update Bulletins N060162 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 12/12/2006 Open
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: 1XWZH0M9 XM Status: Active
Special Coverage 09239 05/19/2006 15 MI 05/19/2016 100,015 MI
Corrosion Limited Warranty 05/19/2006 15 MI 05/19/2012 100,015 MI
Emission Select Component Ltd Wty 05/19/2006 15 MI 05/19/2014 80,015 MI
Bumper to Bumper Limited Warranty 05/19/2006 15 MI 05/19/2009 36,015 MI
Powertrain Limited Warranty 05/19/2006 15 MI 05/19/2011 100,015 MI
Service Contract
07/07/2011 252171 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 151,683 MI
05/27/2009 224884 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 83,427 MI
05/03/2006 A62282 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
---------- Post added at 10:22 AM ---------- Previous post was at 10:21 AM ----------
Vehicle Information
Branded Title
Warranty Block
Service Information
Service Contract
---------- Post added at 10:25 AM ---------- Previous post was at 10:22 AM ----------
OOps got those last 2 backwards
livingez_123
Sandy, OR
You need to set up a PayPal account for all of the VIN's you have been checking. $5 a pop and 99% of people would be glad to pay it for a little piece of mind or making the wrong choice.
doubletapdrew
Geesh...sounds like mine fell off the truck on the way to the dam dealership.....
Or wasn't tied down properly on the train/transport (and maybe hit another car too since the grille was replaced)
If it has 39 carfax hits I'd get the carfax report, only GM dealers report it into the GM service history so if it was serviced at a non-gm dealer it won't be in there. $40 is expensive but it's less than a tank of fuel.
We had an employee go to sell her trailblazer SS and the shop that repaired it after it got rear ended up accidentally repored it as salvaged or totaled or something (it wasn't, just a fender bender). Took a couple weeks to get that fixed.
denalianyone
NYBlackLade08
New York
Good afternoon Drew may you check my vin? I have the car fax but want to see if anything differs from GM. Thanks a bunch!!
1GYFK63868R247212
doubletapdrew
1GYFK63868R247212
Vehicle Information
VIN: 1GYFK63868R247212 Model: 6K10706-2008 ESCALADE SUV AWD
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: W8HUZ0HB XM Status: Active
Special Coverage 11273 06/25/2008 17 MI 06/25/2018 120,017 MI
Bumper to Bumper Limited Warranty 06/25/2008 17 MI 06/25/2012 50,017 MI
Emission Limited Warranty 06/25/2008 17 MI 06/25/2011 50,017 MI
SULEV Emission Limited Warranty 06/25/2008 17 MI 06/25/2016 100,017 MI
Emission Select Component Ltd Wty 06/25/2008 17 MI 06/25/2016 80,017 MI
Corrosion Limited Warranty 06/25/2008 17 MI 06/25/2014 Unlimited
Powertrain Limited Warranty 06/25/2008 17 MI 06/25/2013 100,017 MI
Service Contract
07/18/2012 626427 ZREG----Regular Vehicle Transaction J0100 - Manifold, Exhaust - Right Bank - Replace 43,461 MI
07/18/2012 626427 ZREG----Regular Vehicle Transaction J0101 - Manifold, Exhaust - Left Bank - Replace 43,461 MI
09/21/2011 618258 ZREG----Regular Vehicle Transaction N6638 - Wiper/Washer System Wiring and/or Connector Repair or Replacement 33,895 MI
09/21/2011 618258 ZREG----Regular Vehicle Transaction C7201 - Armrest And/Or Support Assembly, Rear Or Row 1 Seat (Inboard) - Replace 33,895 MI
09/21/2011 618258 ZREG----Regular Vehicle Transaction N9577 - Defroster, Electrical Connection -- Reattach 33,895 MI
04/01/2011 613554 ZREG----Regular Vehicle Transaction N0850 - Front Fog Lamp Bulb Replacement 28,903 MI
04/01/2011 613554 ZREG----Regular Vehicle Transaction C7200 - Rear Seat Armrest Replacement 28,903 MI
04/01/2011 613554 ZREG----Regular Vehicle Transaction N6642 - HVAC System Wiring and/or Connector Repair or Replacement 28,903 MI
11/20/2010 610091 ZREG----Regular Vehicle Transaction C2362 - Instrument Panel Upper Trim Panel Replacement 25,753 MI
06/15/2010 605465 ZREG----Regular Vehicle Transaction B4661 - Rear Side Door Lock Replacement - Left Side 18,975 MI
06/15/2010 605465 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 18,975 MI
06/15/2010 605465 ZREG----Regular Vehicle Transaction C7486 - Arm, Rear Seat Front Pivot - Replace 18,975 MI
06/15/2010 605465 ZREG----Regular Vehicle Transaction B4156 - Outside Rearview Mirror Replacement - Left Side 18,975 MI
12/21/2009 600929 ZREG----Regular Vehicle Transaction E0033 - Cap, Wheel Center - Rear - Replace 15,014 MI
12/21/2009 600929 ZREG----Regular Vehicle Transaction C7201 - Armrest And/Or Support Assembly, Rear Or Row 1 Seat (Inboard) - Replace 15,014 MI
12/21/2009 600929 ZREG----Regular Vehicle Transaction C2859 - Front Floor Console Compartment Replacement 15,014 MI
04/11/2008 509364 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 2 MI
03/28/2008 A47212 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Jhawk79
