Set of tires with out sensors
Woodblocker55
I got a set of 4 winter tires I will put on this fall without sensors . Do I have to look at orange light on dash all winter or is there some how I can shut tire sensor off for the winter ? I really do not want to try and get sensor on 16 inch steel rim with 10 ply tires.
Might be away around this that I don't know about.
I'm sure other have came cross this .
Any info be great ..
Sent from my LGL84VL using Tapatalk
Matthew Jeschke
Sahuarita, Arizona
You could dismantle instrumwnt cluster and disconnect or cover up light. Otherwise, nothing else I can think of aside from installing sensors. They are pretty cheap and not terrible bad to have. Although I never calibrate mine so my light is always on lol
Sent from my SM-G925V using Tapatalk
you can strap them to the center of the rim with a basic hose clamp of the proper size
BG1988
just get a tire sensor simulator device
not sure why it has not been mentioned yet..
the other issue is you may have is the tire place refusing to install the tire to the rim without it
tell them it's except as they are required on MY2007 and higher only
Thank God I don't have tpms on my 03. Just curious tho--where to buy and how much? I hit the ebay link and it's not found there(the link).
Search EBay for tpms delete emulator they’re on the Canada EBay. Not sure why the link is broken. They’re about $100 shipped so in reality you can buy ACDelco sensors for not much more. Plus Im not sure if your insurance will deny any accident claims since they state they’re for off-road use only and they disable a federally mandated safety feature.
Woodblocker55
Woodblocker55
At $100 I can just buy set tire sensors $145 do they fit the 16x6.5 steel rim ? Then I would have sensors .
Woodblocker55
Woodblocker55
Tell me more you talking around the whole rim with a clamp .. or if there's ones the fit the steel 16x6.5 rim that be another way to go. I never had to deal with them sensors at all.
irochj
