Severe problems after trans fluid change
2001 TX Tahoe
2016 Escalade w 130k, no trams issues just following routine maintenance schedule and had the trans fluid and filter changed, not flushed. Now it’s not drivable, slipping, searching for gears but it works fine if I put it in manual. Only out 6 quarts of Mobil 1 synthetic in as that’s all that came out? Could something else have gotten messed up while performing this service?
I had my 2016 Yukon transmission serviced for the first time at 98K miles. Drain, fill, new filter, and deleted thermostat. On they way home from the shop it started running very rough, felt like it was misfiring. Did this about 3 times. Threw a PO171 code. Back to the shop, the code was gone and not stored, he couldn't find anything on his scanner. It was fine after that and it's been about 4K miles since. I wonder if deleting the thermostat caused it to have to relearn something??
Yukon050
A mechanic friend of mine did it in his garage, on the side type deal. I hear you are the trans expert and was hoping you would chime in!
How about next time dont be cheap to save a few bucks taking it to friends. Stick with reputable shops who will back the work performed.
the blur
Cyber Space
You changed tranny fluid after 130,000 mile ??? That's insanity. I won't touch mine because it's never been done, and I have no problems. 120,000 miles... and it's not so pink any more.
whymeintrouble
So you are going to run sorry trans fluid through your trans for an unknown amount of time. Good news is, probably not going to be too long before you can replace it. Changing fluid does not cause issues, issues are already there.
the blur
Cyber Space
Google the amount of trans failures after changing high mileage fluid.
2001 TX Tahoe
As a side note, my transmission was replaced at 50K.
@2001 TX Tahoe Please start your thread in instead of piggy backing on another thread cause the bulk of members here will not see it. Adding your year and model will also help.
legit_b
