Drivetrain - Rear Axle Lubricant Compatibility & Usage
File in Section: 04 - Driveline Axle
Bulletin No.: 99-04-20-001
Date: June, 1999
INFORMATION
Subject:
Rear Axle Lubricant Compatibility and Usage
Models:
1999 Cadillac Escalade
1988-99 Chevrolet and GMC C/K, G Van and P1-3 Series Models
Built after the VIN Breakpoints (C/K) listed.
This bulletin is being revised to add the 1999 Model Year, VIN Breakpoint information, and additional text Please discard Corporate Bulletin Number 86-42-04 (Section 4 - Driveline/Axle).
This bulletin is being issued to inform dealers about the compatibility and usage of the new Fuel Efficient SAE 75W-90 Synthetic Axle Lubricant, GM P/N 12378261 (In Canada use P/N 10953455), with current axles, and with the non-synthetic axle lubricant, GM P/N 1052271 (In Canada use P/N 10950849), for the rear axles on the above light-duty trucks.
Testing has shown that the new synthetic lubricant will chemically attack the Room Temperature Vulcanizing (RTV) sealant. Use only the non-synthetic lubricant, P/N 1052271, in axles using RTV sealant (See 9.5 and 10.5 information below).
American Axle and Manufacturing (A.A.M.) has approved the use of the new Fuel Efficient SAE 75W-90 synthetic axle lubricant for rear axles with the following restrictions:
^ All 8.6 inch axles are compatible as originally built.
^ 9.5 inch axles on vehicles built prior to mid-February 1998 are NOT compatible because RTV sealant is used on the cover pans.
On vehicles built after mid-February 1998 and equipped with 9.5 inch rear axles, synthetic lubricant, P/N 12378261, can be used because the RTV was replaced with a gasket. Other mid-February changes to the 9.5 inch rear axles include a new cover pan and cover pan fasteners common to other axles.
Important : The new cover pan is not retrofittable to the housing of 9.5 inch axles on vehicles built prior to mid-February 1998. A new retrofit kit is available that will enable the use of synthetic lubricant for vehicles built after mid-February, 1998.
^ All 10.5 inch axles prior to March 3, 1999 are compatible if the axle shaft hub seal (RTV) is replaced with P/N 327739 gasket when changing to synthetic lubricant.
As a product improvement, this new lubricant has been released into 1999 current production C/K vehicles built after the above VIN breakpoints (Except HD3SOO models which use 75W-140 synthetic lubricant, P/N 12346140).
It is recommended that synthetic lubricant be used when changing rear axle lubricant for the following reasons:
^ Potential fuel economy
^ Lower operating temperature under severe usage conditions
Important :^ You do not need to wash/rinse any non-synthetic lubricant from the axle cavity when changing over to a synthetic lubricant. However, you should remove debris from the magnet and the bottom of the axle cavity whenever the axle fluid is changed.
^ On light-duty trucks equipped with locking differentials, do NOT use a limited-slip additive.
---------- Post added at 08:54 PM ---------- Previous post was at 08:46 PM ----------
8.25 Inch With AWD
Grade Synthetic
Viscosity 75W-90
So in the transfer case I use synthetic and the rear convetional?
