Slight miss but 6 mpg!!? Need help
Looks like it's been running a little rich. Besides the suggestions that @wjburken had, have you checked the fuel pressure, key on - engine off, and with it running?
EDIT: can you graph B1S1 to see how much it's moving? Has the MAF been cleaned lately?
C
Chetty mo
Yes cleaned Maf. Ordered new one. Yes that o2 goes from .1 to .9
wjburken
Eastern Iowa
What caused you to install the new throttle body and throttle position sensor? Anything particular or were you just pulling the trigger on the parts cannon? Not throwing stones, but it’s always good to know what, if anything, drive previous decisions.
Tonyv__
Bucks county PA
Read if you dare.
It doesn’t get good until the bottom of page 9. I hope this isn’t your issue but it was for me. Wiped out lifter and camshaft. I tried to diagnose everything before I tore into the engine. I also had a slight miss only at idle and accelerating from idle
C
Chetty mo
My scanner is showing in red some values for the throttle position sensor. Position A and B. And absolute throttle position at 5.8% at idle.
Rgray76
